Re: plans for an adjustable bandsaw fence
William Falberg
Have you tried breaking the frame, rotating it to line up perpendicular with your blade, and re-welding it? Seriously: you should hold a straight-edge against the flat of the blade and see where it's pointed; if it's not in line with your fence, you have a tracking problem. If you can't get it to line up, you have a wheel- crowning problem. If your wheel's crown radius isn't equal to your wheel's radius, you have a machining problem; possibly a tire problem. When you stretch a tire over the circumference of a wheel, the rubber in the center of the tire compresses more than the outer edges and this can flatten the functional radius of the crown itself. My machinist takes this flattening into account when he machines the crowns for me and exaggerates the basic metal crown profile to allow for such stretch flattening. Test the entire length of the cutting edge's flat spots for their direction relative to the fence using the same straight edge; is the blade twisting mid-travel? That will change your degree of drift also. There's just so much to worry about. Properly crowned wheels make blade guides unnecessary.(You have to think about that for a while.) I devoted an entire chapter to wheel crowning but nobody's read it so these mysteries go on forever. Blades don't just "drift" ; they cut in the direction they're pointed.
