Tobacco smoke odor removal
Gene Gauss
I'm helping a friend clean out a house that had been occupied by heavy cigarette smokers. We're going to paint the entire interior prior to putting it up for sale. Should we wash the walls and ceiling before just painting over what's adhered to the walls and ceiling? If so, what's a good cleaner for removing the tobacco tar. Also, all the carpeting is going - what would help on the bare plywood floors before recarpeting?
Re: Tobacco smoke odor removal
Talk to a paint store
This is a common problem. Probably TSP will clean off tars. They're likely to recommend a shellac-based primer to cover the walls/ceiling/trim. If you use that, ventilate the house a LOT, and get a vapor mask. The solvent in shellac - wood alcohol - will give you headaches and make you dizzy. A good mask will help a lot, as will lots and lots of air moving through the house. If you're not familiar with how to test a mask for fit, ask the salespeople. Don't skimp on the mask; better to spend some more money than kill brain cells.
You need to share more info,
Keith Newton
I was thinking TPS too, maybe on gloss, but I don't thing so on flat latex. In cleaning up a totaled sailboat, I sprayed it on, then used a garden hose with a nozzle on spray, working my way down from top to bottom, along with a wet shop van just inches below the spray, catching all the rinse water instantly.
But then on flat latex on drywall, you might want to figure in a festool sander, with the vacuum hookup. Or maybe, I think this may be a good application for Kilz.
Re: Talk to a paint store
William Duffield
Zinsser SealCoat and Zinsser B-I-N are denatured with isopropanol (rubbing alcohol), not methanol. Therefore, they are not as dangerous as your described generic shellac sealers. Their MSDSs can be read here:
http://www.rustoleum.com/MSDS/ENGLISH/854.PDF
and here:
http://www.rustoleum.com/MSDS/ENGLISH/908.PDF
They still have lots of warnings, and are not harmless. Read and heed.
Kevin French
I used to clean houses, mostly after fire damage but a couple times we were called in to clean houses of heavy smokers. We use a Chem Sponge to wipe down the painted surfaces. Three times around the bedroom and the tar was still leaching out of the ceiling.
Washing isn't going to do any for it. Find something to seal it.
I knew someone that was working with the company that makes Kilz. If my memory hasn't totally failed I think he said that Kilz could be used to seal odors. The film former in Kilz is chemically different from what paint is made from. It is not unreasonable that it might be more, or less, effective for the task than typical wall paint. Hotels and Motels face this problem so there must be a lot of experience out there.
In any case washing the walls might be helpful. It is not obvious why TSP would be better than detergent for this task.
Jason Roehl in Lafayette, IN
I mostly agree.
ANY detergent will help your cause--but only if the wall paint is somewhat shiny. That is, if it's flat wall paint, don't bother washing it, you'll just cause more problems than you'll solve because the flat paint will absorb your detergent solution too quickly. But, if it's eggshell or semi-gloss, wash it first. This will help the primer/sealer to keep from lifting the nicotine/tar stains into the film.
I would stick with a quick-drying primer/sealer, too--that helps prevent stains from leaching through the wet film of paint. So use a waterborne product, alcohol-based, or an oil-based that specifies a sub-30 minute dry time or so. Two coats of primer wouldn't hurt, especially if the stains are really bad, and thinner coats are better (again, for the faster dry time). Don't think that you can roll on one heavy coat and be good to go.
I once helped paint a mail-sorting facility's break room. Twenty years of smoke stains on the two-story walls made for a potentially ugly job. But, since there were concrete floors with a drain, and the walls had a semi-gloss paint on them, we used our airless sprayer like a pressure washer, rinsing the walls with just water, then put two coats of finish paint on top and we were good to go.
Jason (painting contractor by day)
More about trisodium phosphate, TSP
The main attribute of this stuff is that it is highly basic, not as strong as lye but getting close. This property enables it to dissolve stuff that is acidic. It also enables it to etch stuff that can be attacked by something basic, for example many kinds of finishes. It may even begin to saponify animal and vegetable fats and oils and thereby render them soluble in water.
It is not a detergent. It will not emulsify and suspend stuff, for example greasy stuff.
Thanks for the correction
but Zinsser, which is the product I use, is still pretty potent during application. Fortunately, the solvent is so volatile that my wife forgives me for using it within about half an hour.
Kneale Brownson
For rentals, we used powdered detergent
Kneale Brownson
to wash walls and ceilings, Kilz, sometimes with a recoat, and paints that produced an eggshell sheen. Under carpeting, for both smoke and pet odors, shellac. It's been a long time, so I can't recall why we used shellac instead of the Kilz on the subflooring.
I did a flip house we called the pee house Because the previous owner left their dogs in it for months without letting them out. The plywood under the carpet was so saturated we tried everything we could think of and eventually cut out and removed about three hundred square feet. In the process, we tried Bin by Zinser. It was actually recommended by a paint factory rep for another company, claiming they had painted crack houses with it to kill the odors. Its a off white Shellac product. The problem was that shellac is destroyed by ammonia and there is a lot of ammonia in pee. We painted gallons of it on the floor and it looked and smelled good for about 24 hours. Then the pee came through it and the floor turned brown in the worst areas. We cut out those areas and replaced the OSB and then painted it with oil based Kilz. That worked. The oil based Kilz stinks in its own right, but after a day or two that smell went away. The water based Kilz has far less odor, but I don't know how well it seals odors. Water based Kilz is heavy bodied or has high solids and does a good job of covering the texture of the underlying surface and equalizes the texture. In our case, there are often patches in the drywall where we have touched it up or patched damage and those patches will shine through ordinary paint. We have started to use Kilz tinted gray to cover the often outrageous colors we find in the foreclosures.
There was a point in there somewhere....
What I was trying to say was that what ever you try to seal the tobacco stains must be something that is not soluble in the sealer. If the stain is soluble in the finish, it will float through and the smell will come through. Maybe Bill or somebody already knows the answer, but I woudl try Bin, or water based Kilz and or oil Based Kilz. Paint a wall with each and watch what happens.
Dealing with pee - wandering off topic here
My son bought a house with six layers of flooring - plywood underlayment, carpet, etc. - all saturated with cat pee. He stripped it down to the original floor*, and it still stank. He got an enzyme-based product from a local janitorial supply house that did the job: slathered it on and 24 hours later, the smell was gone. It wasn't cheap (not sure of price), but it was worth it.
*Houses on both sides of the turn of the last century - 1880s to 1930s - in this part of California often have a one-layer floor of 1x4 T&G fir. He stripped down to that layer; going further, and he'd have been walking on air.
Jay Lombardo
We did the electric work for several fire and flood restoration companies a few years back and they all used oil based kilz to kill the smoke smell after the fires. In schools and such we would take down all the fixtures and throw them out because it was impossible to get the smoke smell out of them all completely. Then they would plastic off the affected areas bring in pallets of 5 gal buckets of Kilz and an airless sprayer, overnight they would spray the whole place. Nobody could work while they did this, hence the overnight. When the smell from the Kilz was gone, usually about a day, the place was fresh as a daisy.
