Is there a downside to sawing veneer too thick? I know, not the optimum time to ask the question after the veneer is sawed and glued. But there will be another time........
Too thin and there is a risk of it not being thick enough to avoid the dreaded sand through. But is there a risk from too thick? I targeted 3/ 32" with the idea that it would wind up 1/16" after finishing.
I am about to take the last two drawer fronts out of the bag. Seemingly endless dovetails to follow.
The problem with going too thick is wood movement. The veneer starts acting like solid wood and the thicker veneer will have a tendency to split usually at the seams.
I usually end up with a 1/16th , works well for me.
I had read at one time a book on veneering and I think they recommended 1/8" or less to help prevent lateral movement issues. Thinner is better, but thicker than 1/8" was described as problematic.
My vague recollection on the subject is that thinner veneers can prevent movement issues such as glue separation and opening of joints. Basically the thinner stuff can "give more" kind of like an elastic material over its width, thereby riding out seasonal changes with the substrate.
Maybe someone else will chime in on the reasoning, as the details are lacking in my feeble brain, I just recall under 1/8" being desireable as my take away from the reading.
Your numbers match what Krenov used. I would also suggest that you edge glue those before layup. Linked to an article from David Welter. I met him when I took a weekend design seminar with Krenov. He is an instructor at College of the Redwoods.
Did you crossband, or is this a veneer over solid stock with the grain running the same in both? If they are both running the same, I don't think you should have anything to worry about, if both have the same moisture content.
On page 70 of my link he describes the substrate. He uses a void free plywood. He doesn't like fiberboard products because it doesn't hold screws well. Add veneer to both faces for balance.
I don't think he'll be cutting dovetails in plywood. Bill is too much of a traditionalist for that.
As for adding my veneer over a veneer substrate, I would rather take my chances with either solid, or MDF than relying on the face veneer of most veneer core plywood. I've seen to much failed glue lines in plywood to trust it. Is it 75% or 50% glued? I don't know, but the manufactor knows how little is needed to hold a .030" veneer, sanded to .020" or less, which might not meet the specs for adding .062 ~ 094" on top of it.
Besides, I don't find many occasions where I need screws in my veneered projects.
