OT- Printer Cartaridges
Tom
So our HP printer needs more ink. We went to Staples and the $ was $95. I see on line "remanufactured" ones for about $53.
Has anyone had any experience with these? The site is http://www.4inkjets.com/CN045ANRIC-HP-Ink-Cartridge-HY-Black-Remanufactured?path=search.results&keywords=HP+951XL+inkjet+cartridge
Thanks!
Re: OT- Printer Cartaridges
Re: OT- Printer Cartaridges *LINK*
Kevin French
I've looked at them before but not made the jump. Here's a link to an article that has a link to ratings. Looks like your 4inkjet company had a prefect rating.
4inkjet
TomD
That is why I don't use those things. Kids, however, got interested in T-shirt printing, and I have been looking at them again. The dudes that do T-shirts buy set-ups that feed directly from the bottle. Or they use syringes to fill their cartridges. So the pros, so to speak are refiling their printers, all the time. Epson seems to be the preferred brand. That means that: 1) refilled cartridges are good; 2) if you do it yourself; 3) or can find the good ones. 4) There is a lot of demand for refilled cartridges that can be served by amazon, ebay, local t-shirt, and photography suppliers, etc...
There are forums for t-shirts; photography, printers by brand; etc.... where you can find info on this stuff. At the local level the people selling this stuff are often companies that sell binding, printing, or signmaking.
When you buy a printer, you often have two identical choices with similar model numbers, where the only difference is that one comes with virtually empty cartridges, and another with virtually full. That can be played several ways. For one, if you are going to substitute one of the fancy refill systems, then you can save money by going with the empty cartridges one. However, if you are a casual user, the empty cartridges one may entice you by it's low cost, when an extra 40 would have got you full cartridges, and you wouldn't be facing buying those later for 100, so the more expensive one can be a better deal for some users.
I am not sure on all the details on this, but I think the part that gets clogged if you buy bad replacement cartridges is in the cartridge, so you can alway just unclog it without worry of damaging something important, or you can replace the cartridge. There are theories as to how to best run these printers, whether to leave them plugged in or how to clean them, on these speciality forums I have mentioned.
costco
Joe in a Cleveland suburb
I have not tried it, but I am told Costco refills cartridges at a good price.
Good luck.
paul in AZ
Have you considered giving up on inkjet printers altogether? After similar angst over cartridge prices I went to a laser printer.
My Brother printer itself was on sale for around $100 and the included toner seemed to last forever. When it finally gave out I replaced it for around $60 with a cartridge good for >2500 pages.
HP is not the tech company you think it is. Look at their annual report. They make a fortune on ink. They're an ink company that also sells ink eating printers.
Chuck in Mtl.
I gave up on inkjet a long time age. new cartridges were too expensive, refilling gave very mixed results usually bad and the re-manufactured type was hit and miss. if i need the occasional color print i will go to staples for a couple of bucks. The rest i printer at home with a cheap laser printer good for many hundreds of copies.
Yes, and I like the ink and savings.
Keith Newton
Cartridge World is the one I found out about. My sister tried them first, and they helped her fix a problem in her printer. Their price is about half what I was paying for new HP, that were not but about half full. CW's cartridges are full, so las twice as long.
Not only that, the first time I dropped by the store, I had some of my nature pics out of my HP that I ask them about. When he saw my shots, he liked them so much, that he gave me an older printer than mine, even threw in a few more cartridges for it. He assured me that it was better than the one I owned, so I used up some of the ink in the one I had, then made the switch, and have been very satisfied.
When I questioned the quality of their ink, compared to the HP, he said that they are so close, there is only one or two atoms difference, which prevents lawsuits, but doesn't hurt the quality.
Take your old empties in with you for a refund.
Jerry Nicholson
I have had poor luck with store brand refilled cartridges - short life, clogging, and leaking. I started to work on a printer for a friend that had installed refilled cartridges. There was ink leaking all over the place and, with his permission, I scrapped it. I have an old HP Photosmart 7960 that I use when I want high quality color prints, an HP Laserjet 451 for casual color work, and an HP Laserjet 1320 for monochrome printing. If I had to choose only one of those, it would be the color Laserjet. Toner cartridges are extremely expensive but they will make a lot of prints and, overall, the toner cost per print is quite a bit less than for inkjet printers. I also have a Laserjet IIIp that I bought more than 20 years ago for over $1000. It still works (but I rarely use it) but newer Laserjets are a lot cheaper and a lot better. They might not last 20+ years though!
One added thing: If you are thinking of a new printer, all brands work with Windows but if you were considering a move to Linux be sure to check on what brand and model has proper drivers Linux drivers. HP printers work just fine with Linux.
Jerry
Re: OT- Laser Printer Cartridge Tip
William Duffield
Ink jet cartridges are filled with liquid. Laser cartridges are filled with something entirely different. As the laser cartridge runs out of this gunk (IIRC, they call it toner), it runs out faster where the most printing has occurred, usually a bit left of center, and piles up in the ends of the cartridge. When the copies start to fade (usually first nearer the middle), open the printer, remove the cartridge, give it a gentle shake from side to side, and reinstall it. This distributes the remaining gunk more evenly across the cartridge, and you can get a lot more copies from the cartridge. You can do this several times, but you'll get fewer copies each time.
If you ever get into the gunk in the toner cartridge, you will swear it is something other than dry. Wikipedia is a good place to start your study of xerography: http://en.wikipedia.org/wiki/Xerography
I have a cheap Canon printer. You can buy them online often with free shipping for $31. It costs $38 to buy the cartridges and they don't last anytime at all. I thought about Inkjet and may have to look at them again but I do frequently use color. I haven't looked at the color ink jet machines but will have to do that.
Tom
Thanks for all the replies. I think I will give http://www.4inkjets.com/a try.
Handy fine black filler color
Bill Howatt
The toner powder is very fine and if you want to make black colored epoxy for filling it works very well.
Just don't break the cartridge open in the living room when your wife is home.
Bill
Seems expensive...
John in NM
Last time I bought a toner cartridge it was $100, seems kinda pricey to bust open for some black epoxy.
I use this stuff:
Got it at the paint store for about $10, lifetime supply for coloring epoxy.
No, You break open the "empty" one
Aha!
John in NM
That makes more sense! (or perhaps cents :D )
Of course, I still need to stick to the Proline colorant - my MIL gave us the laser printer (used) in 1998 and I finally had to replace the cartridge last year :D
Re: Aha!
William Duffield
It earlier times, the office Xerox machines, instead of having cartridges, the toner was delivered in gallon jugs. I don't know if they still make machines that do it that way or not. When it came to maintaining the machines, it was much less convenient, but repurposing the left over was a lot easier.
Re: Aha!
Back in the day we had a copier that had Iron filings in it. I don't under stand but that was the "process". My wife decided they were messy and getting all over the place when she opened the machine and looked inside, so she vacuumed them out of there. Of course, the copy quality went to exactly Zero. The technician who came to service it laughed so hard he almost had a stroke. He put them back and did not charge her.
Re: Aha!
William Duffield
There are lots of different variations in the process over the years. Here's a quick summary of xerography, if anyone is interested:
Refill your own laser toner cartridges! *LINK*
Joe Pack
No need to but cartridges, either new or refilled. I have been refilling my own Brother and Samsung toner cartridges for years at a cost of about $15 per refill. Only messy the first time (you will learn, grasshopper!).
I cannot imagine ever going back to inkjet cartridges again! A $150 all-in-one printer and the ability to refill my own toner cartridges....about the same amount I was spending on ink in one year, but now I spread that cost over a minimum of 5 years!
I have used this company for supplies and have had nothing but good luck and good service.
http://www.tonerrefillkits.com/
Don't do it indoors
I have been refilling mine for about 10 years.
The black stuff will escape and when it escapes it will make black all that it touches. I have a wide glass funnel that just fits the opening and in a minute I'm done. Can it ever make a mess if the refill overflows!
Re: Seems expensive...
Tom
The usual thing for black is graphite powder. Most of the boat places sell it, and it can be useful for other things in accordance with the rule of mixtures. It can be added to stuff like grease. It will change the structural properties of epoxy, as would ink. There were a bunch of useful mixtures, or so we thought, but over the years they have largely been debunked.
Still works great for matching marks in cherry.
