Re: Brass on wood lathe
craigd
Caveat: I've not done it, but people whose abilities I respect say is it no problem to turn brass on a wood lathe using wood turning tooling. Oh wait, I have done it, but very little: using a scraping cut, with the cutting edge centered, the tool won't catch and the results are very good (no chatter). No lubricant needed. (This was using wood turning tools and files on brass in my metal lathe).
Regular tool steel works fine, I've used old saw plate to make scrapers to turn brass into cap screws (on a metal lathe), as do files (which are hard to control). Steel wool will polish the brass wonderfully. I don't think brass is all that much harder than, say, ebony.
I don't know how you are going to hold the nut, I've chucked them on threaded rod and let the nut run up against the chuck or used washers/nuts as spacers. I imagine the "fun" part will getting the nut round.
