Morse Taper Problems
don stephan
My PM hollow chisel mortiser has a "female" chuck that slips onto a morse taper at the end of the motor shaft. Yesterday trying to make 1" mortises in poplar the chuck lost its grip with the motor shaft and spun for a few seconds until I backed off the mortiser.
I am ordering Tapermate cleaners for #1 and #2 morse tapers, and will use on the inside of the chuck. The bottom 3/8" of the motor shaft taper has slight parallel grooves around it from the spinning chuck. How should I try to address these slight grooves?
