Scribing to Walls
Scribing to Walls
Scribing to Walls
don stephan
Fortunately I only have to scribe items to walls every few years. An Accuscribe tool works well for me except that the pencil point quickly dulls, leaving a broad line. A .5mm mechanical pencil wouldn't fit the Accuscribe without trying to drill it larger. How do those who scribe all the time keep a fine pencil line?
Re: Scribing to Walls
Sandpaper or a chisel
John in NM
My scribing tool is homemade, so it depends on a snug fit to hold the pencil. Have to sharpen without removing it as much as possible, so I usually use a sharp chisel. Some 150 grit paper might do it as well, but not as fast.
I've never been so good at scribing, so a fat line doesn't bother me much. I'm not likely to get so tight a scribe that a few tenths of mm matter much :D
I don't know what an Accuscribe Is.
What I do is put the material close to the wall, lay a washer on it, put a pencil in the hole and role the washer alone the wall with the pencil, drawing a line on the material. Most of the time I use a belt sander with a 36 grit belt to sand to the line or parallel to the line. Since the washer controls the inside edge of the line, I sand to that, leaving the line, no matter how wide it is on the material. If the fit is close to start with, I just stand the pencil up on the wall and slide it alone the wall.
(Then I use one inch caulking ;) )
Tom Dunlap
Can you change out the pencil for a scribe point? Think of a device like dividers rather than a compass.
Scratch a line instead of drawing one.
Tom
BrianMonumentCO
One question is how do you sharpen your pencil?
If you use a round sharpener it will of course become a coarse pencil ie broad line.
If you sharpen it like wedge with one or more flat sides/faces then it will maintain a sharper line longer.
It will of course become dull but the flat side will still be in the same place.
Keith Newton
Don, you don't tell what you are scribing to, but it looks like that thing would be a bit bulky trying to fit something up to a highly textured rock fireplace.
I normally just use a thin strip of wood, with a hole or notch cut into it, with the pointy end rubbing the target surface, and the pencil pushing down in the hole or notch along the edge.
Like brian, I always sharpen any pencil with a double taper wedge. #2 pencils are too soft for woodworking, so look for 2.5 hardness, and buy a box when you find them. My laminate and cabinet hardware supplier always has a box with their contact info on it, sitting on their counter for their customers, so I grab a handful every time I'm in there.
don stephan
Some very helpful replies here, thanks!
Re: Scribing to Walls *LINK*
I haven't had trouble with the pencil wearing too fast. I use General Tool's little pencil compass, see link below. Fits into just about any spot, cheap, precise.
http://www.generaltools.com/842--Precision-Pencil-Compass_p_251.html
Buy a harder pencil
Dick Coers
A #2 pencil is rated at a hardness of HB. There are 9 harder grades with 9H being the hardest. Places like Michaels sell them in the artist section.
Re: This is an Accuscribe *LINK*
William Duffield
It's made by FastCap.
A couple of the older one- and two-star ratings are moot, as the design has been corrected. If you don't like ordering from Amazon, Woodcraft also carries it, but at full retail.
To answer concerns of some other responders, FWIW, it has a built-in pencil sharpener.
http://www.amazon.com/dp/B0001GUDT6/?tag=googhydr-20&hvadid=36162650200&hvpos=1t1&hvexid=&hvnetw=g&hvrand=18203008812919823600&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_1rhs774ao0_b
