THE WOODRAT IS BACK!
OT- Collectors Wanted
In going through my FIL's garage I discovered an antique (1920's) Warren-Knight Sterling surveyor's level with box, tripod and leveling sticks. Have seen a few on ebay, but none with a full set like this.
Anyone know collectors or where I might find interested parties like on a forum, etm. ?
tia
Re: OT- Collectors Wanted
Paul Blackwell
What are you looking to get out of it?
First
Some idea of value. I've seen several (without the case, tripod or sticks) in the $2-400 range but those are "asking" prices, not actual values. The set may be included in the estate auction, or sold separately, or be given to one of the beneficiaries as part of a will bequest. Either way I'm trying to get a gauge of actual value to the estate.
Any information will be appreciated.
Warren Knight
Gary Smyth
Mark,
This calls for a picture. When it comes to surveying tools condition is key. These were made out of Philadelphia. From their site, "In 1908, C.F. Iszard and J. Henry Warren organized the Iszard-Warren Company to design, manufacture and sell precision surveying, engineering and scientific instruments. In 1913, our quickly expanding company became known as the Warren-Knight Instrument Company. For many years, W-K manufactured and operated at its Center City location. In 1963, Warren-Knight moved to its current location in Northeast Philadelphia." They are still around but don't expect much help there (unless you want to repair) as they get your question quite often and they mostly don't have time. Warren-Knight made (makes) surveying levels and farm levels as well as transits. I think I have some WWII era W-K nautical stuff around. They were a mid level quality firm in the time period you state. You need to check the optics first for cleanliness, then the bubble levels, and if the crosshairs are in tact. Then check screws. Any repairs needed are likely to be expensive, especially repairing crosshairs and calibration. People who buy these typically want to display them, as opposed to using them, as modern stuff with lasers are easier to use and probably less expensive... unless they are exposed brass and not black. If you have a model number it would be helpful as there are old engineering house catalogs still around to check original prices at the catalog date. In Western PA at a really good flea market there will be two or three levels and perhaps one transit available. Some owners think that they have a gem but may only have a "typical" unit, and really not worth much if it needs help. The reason you don't see all you have is that the other stuff likely was sold/collected separately. By the way, in the case a lens hood, soft dust brush and a (usually) spanner wrench ought to be there. Also check the tripod head and the level base to make sure that they mate. Various companies used different threads and sizes of the screw base. The base ought to have a chained "keeper" to protect the tripod threads. I bet that there are W-K samples to give you a start if you stick with ebay. Check "scientific instruments", "engineering tools", or "Warren-Knight" as topics . As to a house for selling. Try tool auctions. These were typically not "good enough" to be considered fine engineering instruments.
Re: Warren Knight
Thanks Gary,
There does not appear to be a model No. and the box certificate is unreadable. I have, however, compared it to pix of the 1922 Sterling model and it appears identical. The tripod and leveling rules have the W-K Brand so they match. As the unit was in a hot attic for 40+ years and the black finish has crackled and has flaked off in spots on the beam. The finish on the legs (I presume shellac) has "melted" into tiny beads on the surface.
Contacted W-K and they were very willing to "recondition" it for me. ;)
I've poked around to antiquers in my area but have gotten nowhere on value so figured I'd see what the storehouse of WC can tell me. I'll try to post a few pix later tonight.
Re: Warren Knight
Gary Smyth
When you send pics include some of the tripod. It probably is not adjustable height, but a split leg with all three bronze points at the ground and at that age should have the old fashioned "butterfly" wing nuts at the head. Look for wood splits there, as they were cranked down heavy sometimes to hold the legs from spreading or put away wet and tightened. Look for a leather strap and buckle on the bottom section of one leg which tied them all together when placed on the shoulder when trekking about. I forgot earlier, also check for a plumb bob maybe a rear lens cover too in the box. All items count toward value. Curious, did W-K reply with a hourly rate? I think the last I got early in the 2000's was $50, + shipping both ways by me.
Bart Goldberg
Brown Tool Auction
Here's the Look
And the box
The legs are fine (except for the finish).
In the box is the sun shade, 2 short steel rods to fit the tightening holes in the parts and 3 small plumb-bobs
PS
Optics are clear, the cross-hairs are intact and centered, but the bubble is slightly (1/2 graduation) longer than the two 0's
Bart Goldberg
Re: Brown Tool Auction *LINK*
Bart Goldberg
Here is the link to the upcoming auction on March 20th. Note that there is time set aside before the auction for individuals to sell there stuff directly.
Brown Tool Auction
Re: Good Idea
Gary Smyth
I'm sure that he is busy with the next auction, but Clarence Blanchard is the guy who runs the auction. He also puts out the Fine Tool Journal. Whatever association I had ended some years ago but as I remember he was very approachable. You might give him a try. He is in Maine.
Done
His response confirms what I suspected, that we don't have a "jewel" and these things are not "collected" by the tool junkies.
Thanks for the info and responses. It will go up in the estate auction.
