Refinishing floor question
I looked at a house that has about 300 SF of 2 1/4" oak flooring with serious wear and huge Vee grooves in it. the grooves have got to be at least a 1/4" wide. The floor is grimy and black. How do you refinish the grooves? I can't imagine sanding enough of the floor away to eliminate them.
I dreamed up a possible solution. A router with a Vee bit and a shoe on the router that would have a guide strip on the bottom that would fit in the groove and guide the router down the trough. Wonder if that would work and how long the bit would last. A rough calculation indicates about 2000 Lf of grooves. I know you could hand scrape them, but I don't think my shoulders would stand for it.
Any suggestions?
Re: Refinishing floor question
AZ in Colorado Springs
Interesting idea. You'd be able to get to within a few inches of the wall, depending on the router you used. That would leave a lot of clean up work at the end of each groove.
Leave the grooves as is!
Sandblasting?
Basil
Actually, I was thinking more along the line of bead blasting or dry ice to remove the black using as low an air pressure as needed to do the job on the grooves.
Re: Sandblasting?
john Veerkamp
May even blow out satisfactorily with just compressed air.
Jim Hoeller
I helped a friend clean a similar floor using Murhpy's Oil Soap with Scotch pads on the bristles of a scrub brush. The scratches weren't quite as wide but did hold a lot of grime. We let the soap sit for a bit on the scratches and then used the brushes alone to clean them. The Scotch pads were barely wet when used and we cleaned small areas at a time rinsing with clean water on a damp cloth. it looked pretty good when completed.
Jason Roehl in Lafayette, IN
One of those... *LINK*
...gets one of these:
http://www.amazon.com/Allway-Tools-Contour-Scraper-Blades/dp/B000BQMZ9C/ref=sr_1_1?ie=UTF8&qid=1395261161&sr=8-1&keywords=profile+scraper
These scrapers even come with a half-round file held in the handle magnetically, and they work really well when it comes to scraping floor grooves.
Alternatively, get a 2" carbide scraper (the blade on the 2.5" carbide scraper breaks too easily IMHO) and scrape both sides of the groove. It's really not that bad, and because you're concentrating on such a small strip, you don't have to bear down on the tool that much, if at all, which should spare your shoulders.
Jason
Allway Scraper
Jack Guzman from Maine
I'm with Paul
I would clean the floor as good as possible scrubbing the grooves with a brush and then refinish the flat leaving the dark grooves. I think you'll find when all finished they won't look bad at all. Scraping those grooves sounds like a form of corporal punishment.---Jack
