Grizzly oscillating spindle sander
Paul Blackwell
Anybody know of an easy way to change the sanding tubes? My machine has 9" long spindles from 1/4" to 4" diameter. I remove the nut and washer on the top, and even drive the metal spindle from the rubber tube and still can't budge the sanding tubes. Usually I have to destroy the sanding tubes to remove them, and then can't get the new ones more than about halfway on before they seize up and I can't move them. Pounding on the tubes doesn't work. Is there some lubricant that would work? I hesitate to use any oil product since it might soak through. I tried a dry lubricant (graphite, I think) but it doesn't seem to help. I measured the sanding tubes, and they seem to be about .030 inches larger than the rubber cylinders. Any suggestions greatly appreciated.
Re: Grizzly oscillating spindle sander
terry gearhart
terry gearhart
I have one and have no issues changing spindles.....underneath the table there are 2 half nuts, the top half nuts goes up against the bottom of the spindle and you turn the bottom half nut, the top half nut will push up against the spindle pushing it out.....if you continue to have issues, call Grizzly tech support, hope this helped
Try this
Grant in Iowa
Paul,
Not sure about your specific model, but I have a Porter cable OSS and find the following solution to your described problem:
I remove the entire rubber drum and sandpaper after removing the retention bolt on the top of the assembly. Then I roll the whole thing on a table like you might with a pie dough roller. This action seems to loosen the two parts, allowing for easier removal.
Again, not sure if you can remove the assembly like that on yours but the approach works on mine.
FWIW,
Grant in Iowa
A couple of suggestions
Yonak
..A couple of tricks I've heard : To help get the old sleeve off you could try rubbing some corn starch on the drum before installing. To get the new sleeve on you could put the drum in the freezer for 30 minutes to shrink it a little bit.
Paul Blackwell
I'm not having trouble removing the spindle assembly from the machine. The problem is in changing the sandpaper cylinders. I can't get the sandpaper to come off the roll without cutting and peeling it off, and then I can't get the new sandpaper cylinder on the rubber tube. It goes about halfway on and seizes up and I can't move it further. I have driven the metal center spindle completely out of the rubber tube so nothing is expanding it, but still have the problem.
Re: Try this
I take Grant's process a step further. I put the rubber cylinder (bare without paper on it, and no shaft in it) on a hard flat surface like my tablesaw and use a board to roll it back and forth, pressing as hard as I can. I'm trying to make it more slender and longer. The rubber needs to warm, otherwise its as hard as a rock. This works for a while, but is not permanent.
Robin Corell in Atascadero,CA
It sons like you might be over tightening the nut that expands the drum. it doesn't need much more than finger tight.
Often times letting the drum sit overnight off the mandrel without a sleeve will let it relax a bit and go into a sleeve easier.
your on the right track by removing the drum from the spindle. Insert the drum into the sleeve slightly rotating it as you gently push. Once it starts to bind stop pushing. place the sleeve on a hard smooth surface such as the table of the sander with the drum sucking out the top of the sleeve. Lift the sleeve about an inch or so above the surface and drop it so that the edge of the s sleeve strikes the table squarely , as oopposed to one edge hitting first. You may have to repeat this 20-30 times to completely install the sleeve but I guarantee it works.
Kneale Brownson
I use Grant's and Ray's suggestions
Kneale Brownson
for my PC hand-held oscillating sander sleeves.
Paul Blackwell
I tried using baby powder, and still can't get the sanding cylinder more than about 2/3 of the way on. I called Grizzly technical support, and he said to try putting the spindle with the rubber cylinder on the machine, turn it on and using a strip of sandpaper, remove some of the rubber. I tried this, and still couldn't get the sanding tube on. Very messy, I might add. The rubber cylinder is currently residing in the freezer I'll try again tomorrow with baby powder. I almost think the sanding tubes I bought (from Grizzly) are slightly undersize from normal. Doesn't seem to me that the job should be so hard.
Another thought
Ray - Middletown, IN
Try wrapping it tightly with something elastic for a few hours, then quickly slide the sleeve on before it expands.
Ray
iew
I went out and tried to remove sleeve from spindle while still in sander, grabbed sleeve and no way was it coming off. Then I lightly touched the sleeve and it slid right off. Hmmm.
