Anything wrong with modding a Biesemeyer this way?
Henry Higginbotham
For years, I used an Incra TS fence system on my Unisaw. The fence itself is an aluminum extrusion to which you can mount just about any sort of accessory. Feather boards, fence stabilizers, height extensions, etc. I kind of came to take this for granted.
I recently changed over to a Biesemeyer commercial fence which has no such mounting provisions. I'm thinking of adding three or four 1/4-20 rivet nuts along the top of the tube. When nothing is attached via the rivet nuts, they would be comfortably below the height of the sides of the fence. But when needed, all sorts of shop-made gizmos might be attached.
I don't readily see any reason not to do this, but then I know that I usually find out why I shouldn't do something after it's too late. But I'd bet several of you have done the same thing, so what worked or didn't work?
