SCMS technique
SCMS technique
SCMS technique
Pat Evans
TV programs show SCMS operation of pulling the blade out and then pushing it back through the cut. I always thought that was dangerous as the blade would tend to lift the workpiece off the table. However, I just read an SCMS manual and that is the recommended method, supposedly to prevent the saw from climbing onto the workpiece and causing loss of control. I still prefer pulling to pushing. What do you experts say?
Re: SCMS technique
Jason Roehl in Lafayette, IN
Re: SCMS technique
It depends on the hook angle of the blade. With a negative hook angle (many, many miter saw blades), the blade won't lift the workpiece. It also makes it easier to mark the workpiece--out front where it's easier to see and where you can take the blade teeth on the lowest portion of the blade to the mark before you make the cut. Out, down, in--has worked for me with my DeWalt SCMS for over 10 years.
Jason
Re: SCMS technique
Re: SCMS technique
Dave's Not Here
Pushing is the correct and safe way when using a SCMS.
Re: SCMS technique
Re: SCMS technique
Dick Coers
Push with one option. If I want the supreme quality cut, I will bring it down just enough to score the surface on the pull out, then push in for the full cut. That is my usual cut on plywood.
Re: SCMS technique
if you pull, it will come after you
del schisler
if you pull the blade it has a pulling affect and comes after you , pushing in my opiong is the best , most board's are heavy enough as to not lift, and also are held down some what by the OP . on a small board like 2" would be like just a chop , a wide board is where things change. my 2 cents
Re: SCMS technique
Re: SCMS technique
Paul Blackwell
If you've ever operated a radial arm saw, you would never want to use the pull technique. When I first started my shop, I bought a radial arm saw. It was the first thing I got rid of. It scared me to use it. If your workpiece is narrow enough to cut with just a plunge cut, lock the saw and do that. Otherwise, use the pull, down and then slide method. I've had my DeWalt SCMS for many years, and never had a piece try to lift up.
Re: SCMS technique
Re: SCMS technique
Sgian Dubh
An interesting observation Paul because the normal operating method for a cross cut on radial arm saw is to pull through the cut. One reason for this, if you've not set the job up with a stop to determine length, is so that you can align the blade with a mark on the wood. Even if you do use a stop for repeat cuts, by cutting on the push stroke, you have to pull the saw out after the cut, reach around and move the 'offcut' on the right hand side of the blade leftwards across and behind the blade to position it for the next cut. That's not something I'd ever teach a learner to do. Slainte.
Re: SCMS technique
I always push...
John in NM
No problems with the piece lifting up.
If you are going to pull, you need a zero hook or negative hook blade to keep it from rushing you as others have described with SCMS's and radial arm saws. The chop action of the SCMS is what makes this push cut possible where it is not possible, or I should say practical, with a radial arm saw.
That the saw can lift up over the work on a SCMS is probably also what makes the pull cut seem fairly tame, but it also makes it extremely dangerous in my mind. I found the big RAS controllable due to it's height and being able to put my shoulder into resisting the advance of the saw when cutting heavy wood that pinched - the only time I had problems with one rushing me using a negative hook blade. I did once use a friends RAS that he'd put a 20 degree hook framers blade on - absolutely terrifying! :D
Re: SCMS technique
Clint Searl
Re: SCMS technique
Clint Searl
Generally, I cut on the push, but in heavy hard stock the blade (especially the 10") tends to get pinched toward the end, so I'll make a not-quite-through-cut on the push and finish with a pull. No bind; no burn.
Re: SCMS technique
if you pull use the correct blade
Robin Corell in Atascadero,CA
If you pull your scms you are effectively converting it to a radial ark saw and you should use a Bede with a negative rake tooth.
