Re: I agree
Ed Wozniak-Buffalo, NY
Believe it or not capacitors have current ratings as well as voltage ratings. When a capacitor is connected across an AC voltage source, like an AC power line, current will flow through the capacitor. The ~ symbol next to the 250 V marking on the part indicates that the part has an AC rating and can handle the resulting current that flows when it is connected across a 250 VAC line. The 1000 Volt part suggested may work but then again it may not.
Also not all capacitors fail in the same way. Your capacitor blew up but nothing else caught on fire. Some capacitors can fail in a way that they will cause them to continuously generate heat and potentially cause a fire. It is best to try to find a capacitor that is specifically intended to be connected across an AC line.
