test message
test message
test message
ken chase
I've had a problem with my password and changed it earlier. Appears
something hasn't worked and my earlier posts did not appear on the board.
If this fails I guess I'll look for another board even though I've used this one
at least 20 years on and off.
Thanks
Ken
Re: test message
Re: test message
You got it figured out, Ken. If you ever get a password error, it means your cookie contains something that is different from the profile you registered here. Check your profile credentials and then set your preferences to the same username and password.
