Half round table - The legs are on
Joe in a Cleveland suburb
I cut the mortises for the back legs last night and stuck them on the table.
I used my mortising machine to do that and an LN block plane to fine tune the tenons for a good fit. Worked out ok, no problems.
The bridle joint for the center leg went ok as well. It's not as perfect of a fit as I wanted, but nobody will ever know...
The only thing that will be a problem now is that the back legs aren't perfectly aligned. I was going to attached the back apron with a DT joint. But the backs of the back legs aren't exactly in the same plane if that makes sense; both are kinda skewed inwards. So I guess I will have to do some tweaking here and there for a good fit.
Now that the legs are on (not glued yet), I am second guessing them. I'm thinking about re-doing them and making them tapered instead of turned. Not sure I like it. I don't know, have to think about it.
Re: Half round table - The legs are on
legs
When you first revealed the round legs I had a raising of eyebrows. Not what I was expecting. Then comes the picture of the whole assembly. I like it. It has a pleasing modern look about it. Now you will have to come up with an edge treatment to compliment the leg, maybe a bull nose or half round.
If you want to try traditional tapered legs make a second table. This one deserves to live on.
Re: legs
Jesse Cloud
Bill's right, those legs deserve to live!
Its really looking good.
What are your plans for the top?
Progress
Hi Joe,
You're learning a lot on this project, and the results show it. If I had to offer constructive design criticism here, it would be to really articulate the tapers, whether you saw them or turn them. I would decide if I wanted a straight taper or something with a little curve to it, as you've done here. Regardless, make them consistent with each other.
When you have turned legs, there's also the question of how you transition from the square to the tapered turning. I like the simple treatment you've come up with, and I'm not sure you've considered other options, but as the others have said, the design works as is. It's most important to do what suits you best.
Thank you for the feedback.
It's appreciated.
Re: legs
"What are your plans for the top?"
I have some curly maple I plan to use for the top.
Thanks.
Re: legs
"an edge treatment to compliment the leg, maybe a bull nose or half round"
Do you mean along the bottom of the apron?
I was thinking about doing that.
Thanks.
