Spring loaded hinges
Howard
I'm making a small cabinet with a hinged door that is held closed with a clasp. When I open the clasp I would like the door to spring open.
Anyne know of a source of small leaf springs (a couple of inches in size) or euro style hinges that are spring loaded?
Thanks
Howard
Re: Spring loaded hinges
Re: Spring loaded hinges *LINK*
Keith Newton
I'm wondering if a touch latch would work. Here is a link to the type that i use most.
Other than that, you might drill a hole into the side or wherever would work best, for a spring to fit down into, with maybe a dowel on top to transfer the spring pressure. Most good hardware stores will have an assortment box or drawer of springs of various sizes and types.
http://www.thehardwarehut.com/catalog-product.php?p_ref=4545&gshop&gclid=CPDtw62DjL0CFSXl7AodMHIAWA
Howard
Thanks Keith
But a touch latch won't work in this instance.
Howard
Keith Newton
Howard, You don't give a lot of detail to work with, but if you don't like the idea of a spring down in a hole, with a plunger on top, have you thought of making a wooden leaf spring? That seems pretty easy to me, and would certainly look hand-made.
William Duffield
Have you investigated Blum Tip-On door openers? They offer an adaptor plate that clips directly to their euro hinges, so if your application (whatever its configuration) works with euro hinges, it should work with one of these.
http://www.cabinetparts.com/c/hinges-european/hinges-blum/tipon-for-doors
Note that I haven't used these, but have used several other Blum hinges, which are all of good quality. They appear to attach to the hinge at the same place as the Blumotion soft closer mechanism, which I have used. It appears they also offer options to drill a hole to install them so they are exposed in the front edge of the carcass side, or screw them to the inside of the carcass side.
Howard
The door is twenty inches wide, six inches high and about one inch thick. It is hinged at the top with a clasp at the bottom. It is closed in the vertical position and when the clasp is opened the spring hinged should open the door about ninety degrees to approximately a horizontal position.
Howard
William Duffield
So, you have to find a spring that will support the whole weight of the door, right? That's a horse of a different feather!
I've installed these AKURUM cabinets from IKEA, but their opening and supporting mechanisms are massive, and may not fit a cabinet door only six inches high. Also, I don't know whether they sell the mechanisms individually. Of course, you could buy a complete cabinet door, and cannibalize the hardware.
http://www.ikea.com/us/en/assembly_instructions/akurum-wall-cabinet-frame-horizontal__AA-424493-3_pub.PDF
The openers are shown on pages 5, 7, etc.
How is your search going? *LINK*
Keith Newton
I'm not sure what your goal is, if it is supposed to flip it up like a jack in the box, or mainly to hold it open while you or someone views CD's or something inside.
If the main goal is to hold it up, I was thinking about some lid supports that I used long ago that came up with no resistance, but had an adjustable brake, which could be set to hold it there. But then to close, only a light touch would start it down at a very nice slow speed. However, I think they may be too long to work with only 6" of height.
So, if you are destined to make something of your own, rather than a leaf spring, I'm thinking that maybe a torsional type be a lot easier. Here is a link that shows some examples, in the second to bottom row. I think you could mount it up near the top corner of the side, behind the door, and fit it over a dowel, then let one arm push the door out and up, with the other end, bent outward toward the cabinet side, drill the hole where it needs to end the thrust.
Springs are not too hard to reconfigure. A small torch will heat the wire ends red, so they can be bent for your specs. You might need to insert the action end into some slippery plastic finger, to extend it, and keep it from wearing on the back.
http://www.ronet.polfirms.eu/en.html
