OT Garage floor coating
Paul Blackwell
Information only about epoxy garage floor coating. Last summer I investigated having a true epoxy floor coating done on my garage floor. I had bad results with epoxy paint on my garage floor in my house in Newark, NY before moving to a new house. This is NOT epoxy paint. The process is a three day operation. Day one they diamond grind the floor to remove all dirt, sealer, grease etc. The process was remarkably dust free (large vacuum system attached to the grinder). The grinder resembles a large floor polisher. Then a two part mix of clear epoxy is applied as a primer. Day two: Another epoxy layer(colored), this time with color chips broadcast. Day three: Another epoxy coat to seal the color layer. This coat had some fine sand mixed in to give it some texture. The result is beautiful. In February we had a couple of warm days, and I wanted to see what the salt and junk dripping from the cars had done to the floor. I just hosed it with plain water and it rinses clean and looks like new. I'm very pleased so far. Cost for a two car garage was $1500. To complete the job, I had the drywall joints finished, insulated the unfinished wall, put up Smartside panels and painted.
Re: OT Garage floor coating
Frank Orfanello
Paul,
Where are you located? Do you mind saying who did your work?
Paul Blackwell
I'm in Macedon, NY which is just East of Rochester. The work was done by Garage Solutions, Tom Hodgson owner. Phone is 585 645-2298, Cell is 315 576-1516. So far, the floor looks great. No apparent damage from salt, etc. Clean-up is easy with just a hose.
John in NM
Interesting about the epoxy paint. There's talk of using something like that at work on some steel floored rooms. What were the bad experiences, if you don't mind my asking? Stuff like this is something where my input actually makes a difference - because the purchasing guy listens, not the bosses :D
Henry W
No experience with epoxy products - just a comment.
I am certain that epoxy products, like other coatings, can only be as good as the surface and surface preparation.
This is not a commentary on the OP's experience with epoxy paint, but a reminder that not all coating failures are the fault of the product.
Henry
Paul Blackwell
The epoxy paint was applied to an older cement floor in my garage. The cement was in good condition and I followed the directions to clean the floor prior to painting. Initially, the paint looked good, but after a year or so of driving the cars on it, it began to lift off where the tires rolled on it. I tried to avoid parking on the floor with hot tires (right after a longer trip), but it just didn't stand up. I didn't have access to a method of diamond grinding which is what the applicator for my present floor did (see original post). Whether or not this would help with paint vs. the epoxy coating, I don't know.
thanks!
John in NM
Useful info :D
Probably we won't have that problem, since this is on the 4th and 5th floors, no cars :D, but I remain concerned about surface prep, since the floors have been painted repeatedly with latex floor paint that doesn't hold up.
My preference is to switch to a real enamel rather than a latex product, since the prep work will be minimal. One of the guys is enamored of epoxy paint, I suspect more from the sound of it than any experience with it. If we have to strip these down to bare steel before painting that will be a huge pain.
Jason Roehl in Lafayette, IN
Re: thanks!
I hate to be the bearer of bad news, but whatever you put down will only be as strong as the weakest layer of paint below it. Whether that's a 2-part epoxy or a "porch and floor enamel", if you have a soft paint underneath a harder coating, there's bound to be chipping, cracking/crazing and peeling. And like many other things in life, there's a broad range of what you can spend, especially with epoxies (it's not hard to find a product that will set you back north of $5/s.f.).
I'm always a fan of a good mechanical bond--abrade the substrate. Chemical bonds can be excellent, too, but they're often prone to unseen contamination or unknown interactions with the substrate if there are prior coatings.
Jason
Exactly....
John in NM
That is why I favor the middle course. The latex on there is up to routine foot traffic, but tends to scrape off when crates and stuff get dragged across it. My hope is that enamel might be a bit tougher in regards to scrapes, since it tends to be a bit harder. Worst case is it's just as bad and we keep recoating with enamel every summer like we end up doing with latex.
Given the use, I actually have little problem with the stuff we've been using. I don't really think that paint holding up to dragging equipment and crates across it is really a reasonable expectation :D And recoating is a breeze - about a day's work and dries fast.
But the guy who does the most of the maintenance is absolutely convinced that the problem is the paint, so rather than argue about it ...... :D
Heck, I think I just talked myself into advocating for more latex! :D :D :D
Frank Orfanello
Thanks.
