Backerboard for crown molding
AZ in Colorado Springs
Hello everyone
I'll visit my daughter in Virginia next month, and she's asked me to install some crown molding in her townhome. I have a sample of the molding and will make backer board to go behind the molding. I'll rip some 2x4s for the backer board. I live in Colorado (dry climate) and as I mentioned, she's in Virginia (humid climate).
So, my question is whether or not I should flatten the 2x4s on the jointer prior to ripping them. That, should they be flattened at all? or should they be flattened here then taken to a more humid environment? Is this even worth worrying over?
Thanks
Andy
Re: Backerboard for crown molding
BrianMonumentCO
Are you certain that you need a 2by4?
A 1by4 might be cheaper and would already be dried.
Remember to let your wood acclimate to the house before installing.
Will you be taking wood with you or buying wood there?
I'll rip the backer board here in CO and take it to Virginia. I won't have a way to rip it there. (I'll will take a CMS to cut the crown molding).
Jason Roehl in Lafayette, IN
Unless it's some fantastically huge crown molding, a 2x4 ripped into a wedge shape will be flexible enough to pretty much follow the wall and ceiling.
What you want to make sure you do, however, is to rip the 2x4 SMALLER than the cross-sectional gap between the crown and the wall-ceiling intersection.
Ideally, you'd leave at least a 1/8" gap between the backer and the crown to allow for variations in the wall and ceiling, and to allow a little fudging on the placement of the crown.
Jason
Dick Coers
I don't like to buy 2x4s even a few days early and let them sit around. Let alone, rip them smaller and then let them sit. You are going to get some bananas, so rip extra. Keep the ripped pieces clamped to a bench or at least to each other as they dry in your shop. Unless you install them with screws, I don't think you will be able to pull the worst ones in with nails. As suggested, rip them small and I guess rip extras. You're going to need some luck!
John McGaw
Why not plywood? Even common construction stuff is likely to be straighter and more stable than 'good' modern 2X4s.
David Yoho
If you'll be anywhere near the Richmond area you could wait to buy your 2 X 4s here and rip them. I'd be glad to offer you the use of my saw and shop. I'm in the area and easy to get to. Glad to help if needed.
Thanks for the advice
Thanks, everyone, for the answers and advice. I'll consider the plywood, as was suggested. Also, I will install the backer with screws -- McFeely's square drive, the most convenient fasteners I've encountered -- which should make it a bit easier to pull everything flat.
Andy
Re: Thanks for the advice
fred in ct
When I put up 3-1/2" crown in my LR I put up 1-1/8"x 1/4" ply on the ceiling and wall, nailed and glued with const adhesive, it's been up 3 yrs now with no problems, you don't need to fill the whole cavity behind the molding, just have to get something to hold some nails.
