OT-Computer question
Tom
Our desktop pc seems to be "struggling". By this I mean the fan seems to be working extra hard at times.
Any thoughts?
Re: OT-Computer question
John Brown
I had that problem once,it was dirt/dust inside the tower and built up on the fan. Get an aerosol can of air from some place that sells computers, open the tower and blow it out. If that doesn't help it probably needs new fan.
Jack Guzman from Maine
I've had those fans burn out on me. They are fairly cheap and easy to replace.---Jack
John McGaw
Several possibilities: 1) the processor is actually working very hard, burning a lot of CPU cycles, and this is causing the thermally-controlled fan to run faster than normal; look for a newly installed or upgraded program as a culprit and note what you are actually doing at the time of the noise 2) the fan itself is dying -- the bearings in some of them are pretty feeble and don't last long 3) there is a lot of crud built up in the heatsink and that is causing the CPU to overheat [see number 1] and 4) the heatsink assembly has come loose from the top of the CPU making it overheat and revving up the fan; this on is most likely to crop up right after a computer has been moved and treated roughly.
One good step in figuring it out is to download a program that monitors the computer's vital signs. There are a few different well-established free programs available to do the job.
del schisler
i didn't read the other post's , maybe that the heat sink grease is drying up and may need to redo the processer , this should be done by some one that know's, it is not a diy er thing, don't know how old comp. is . the fan is to cool the processer so have that check , before it take's a dump. If this has just started than do it right away. the fan is ok , their is a litter sencer on the processer that tell when to come on , so something is going on ,
Howard Acheson
Are you sure it's the fan you are hearing? Most often its the hard drive doing some things it does automatically. For example, my drive just ran for a couple minutes as the computer ran a virus check.
Tom
Thanks for all the replies! I will start with the dust removal. Don't suppose my shop compressed air would be a good idea!!
waroland
Sure, just crank your regulator dow to 30 pounds or so.
Bill Howatt
Well the shop compressed air will certainly be good enough to start an argument.
Actually, I have used it with the pressure turned down and for better or worse, I usually try to ground the nozzle to the computer chassis. This should start an argument too.
If you suspect a noisy fan you can use the trick of a length of dowel against the fan with the other end at your ear as a poor man's stethoscope.
For fans other than the CPU fan you unplug them and see if it improves - just make notes of where the cables go to restore them. Don't unplug the CPU fan!
Bill
Bill Turpin in WNC mountains
Recently scrapped out an old CPU that had similar loud fan noises. Three inch diameter fan fastened to aluminum heat sink that was fastened to CPU. The micro slots in heat sink were totally stopped up with dust. It was impossible to blow it out. Partial disassembly was necessary to get it out enough for processor cooling. Have fun.
Bradkansas
I did not read the other contributions to the question but, take it apart and blow it out (outside) with a compressor not a small can of air.
Danger Will Robinson!!
David Yoho
I've been successfully using my compressor to blow out my desktop units for years. One thing I learned the hard way is not to allow any fan to spin freely during this or you will shorten its life. I use a small dowel to hold the blade to prevent it from spinning at too high a speed.
If you hear noise coming from a fan it usually means the bearings are bad or going bad and will need to be replaced.
Another reason your CPU fan might be running harder is if there is something on the computer running that taxes the CPU.
Chuck in Mtl.
You did not specify which fan was struggling...there is also the PSU fans and perhaps some extra case fans in addition to the cpu fan.
Jerry Nicholson
I have seen the heat sink assemblies on the CPU packed so full of lint and dirt that the CPU overheated and failed. In some cases, I have disassembled the heat sink/fan assembly to clean the dirt out but this requires cleaning the bottom of the heat sink and the top of the CPU chip and applying new thermally conductive paste between them. I have also repaired many stuck fans by pealing off the seal over the bearing and applying a little really light lubricant. WD40 has worked for me, possibly by liquifying the old lubricant. I then turn the fan with a vacuum cleaner, probably to a much higher speed than intended. So far I don't know of any fans that I fixed that way that have packed up and failed again.
I would be really careful cleaning out the computer with shop air. You could blow grit in places you didn't want it (CD drive, for instance) or build up a disastrous static charge. I am really careful using a vacuum too because the air flow into the vacuum can also build up static charges.
Jerry
John McGaw
Good point and one that I should have thought to mention. Luckily it is usually fairly easy to figure out which fan is causing noise once a computer is open and operating on the bench. I've noticed that the fans in cheap power supplies are often candidates for early failure and, sadly, too many computer makers seem to choose their PS units based on 'what is the cheapest thing that will just barely do the job and will possibly outlast the warranty period'? This is just one of the reasons I build my desktop systems from scratch. If it is the PS fan acting up it is almost always possible to replace it with an equivalent although a bit of knowledge and skill are needed to safely muck about with the gubbins since potentially lethal voltages are hidden in the metal box.
