neat carving table
hapajeff
A fellow made a fully adjustable, highly articulated, very stable welding table that could just as easily be adapted for wood carvers:
www.youtube.com/watch?v=_OnF6_V28DM
neat carving table
hapajeff
Re: neat carving table
hapajeff
And here's his video on the parts and construction:
https://www.youtube.com/watch?v=FVz-eDkeF30
It seems to me there's no reason why the frame and ball chuck couldn't be made from wood.
Keith Newton
Oh Yea Man, I like that a lot. There are certain things i would do differently. One thing, would be to increase the inner ID of the top ring, which would give more layover range.
I think you could tap that ball for a lot of different fixtures to attach, like having a stud with threads to match my lathe faceplate,
Yonak
A bowling ball and brake rotors .. the man's a genius.
William Duffield
I've had an old bowling ball rolling around on the floor of my shop for fifteen years, waiting for the inspiration to build a carving table. This guy's ideas certainly bring it a lot closer to reality.
Now, I need to find a bottle jack. I'm not going to cannibalize my floor jack, which is three tons, and overkill. And, I'm not going to use the bottle jack on my SawStop industrial mobile base, either, but that one is a much better size for this. SawStop's jack control mechanism is a lot more compact, and should be adaptable.
I like your idea of multiple, removable tool mounting adapters. I can think of four off the top of my head that I would find useful:
1-1/4"-8 tpi and 1"-8 tpi for mounting scroll chucks from my lathes
#2 Morse Taper, with hole drilled clear through the bowling ball for a draw bar, to hold a Jacob's chuck. Since an exposed head would interfere with the lower clamping ring, the head of the draw bar would need to be recessed. Probably an allen head cap screw would be required.
Approx. 46 mm round hole to accept drill press table posts.
One must be careful when designing mounting methods for a bowling ball. While the outside is a flexible, hard plastic, the core is often cork.
Keith Newton
I have 4 cheap bottle jacks of various sizes, but they all have a screw in release. I wonder if there is some off the shelf valve that could replace that. The pump side lever would be easy.
I would never have thought the inside would be something as light as cork.
I used this ball in a socket with a captive ring to make articulating shoulder joints on some anthropomorphic sculptures a long time ago. I think there is still probably a prototype out in the dark recesses of the shop somewhere. Although, the ring tightened with Allan screws, which wouldn't be a bad solution for this.
I was also thinking that three legs would suite me better, in that I would want to get in straddling it to have the work where I want it. If there were three bolts tightening the two rings together, only one would need to be loosened to free the ball, which eliminates the need for the jack altogether.
Yonak
My concern about three legs is stability. Couldn't you use four legs and still orient it so you could straddle a leg ?
I have thought about this a bit and wonder if the jack is necessary at all? The range of motion of the lower ring only needs to be very small, basically from snug to tight. Would a foot lever do that? Would it be effective and comfortable to hold it with your foot while you work? How about some kind of snap arrangement like a buckle or clamp that holds a lid down. Maybe De-Sta-Co has something.
The disk brake rotors look good but I wonder if wooden rings wouldn't work as well? Perhaps a sturdy plywood ring for the top and maybe for the bottom would do it.
William Duffield
You might find some pertinent ideas in the SawStop Industrial Mobile Base User's Manual, which you can download here:
It is a very compact arrangement, and works very well. It as two control pedals. The one marked "lower" is connected directly to the release valve. The other pedal operates the piston pump, and also pushes down on the other end of the "lower" control pedal, closing the valve.
Off on a tangent: I have used, assembled, adjusted, fixed and sold many mobile bases of many designs and materials for woodworking machinery, and this is by far the best I've encountered. It effortlessly and silently lifts almost 800 lb. of saw, fence and whatever I might have piled on top. When I step on the "lower" pedal, it just as silently sets the saw back down, with all four corners of the cabinet firmly on the floor, with no wobble or other instabilities.
Well yea, That helps.
Keith Newton
It wouldn't be hard to convert almost any bottle jack by making a new lever rod with a foot petal, letting it run through, so a return spring could be added on the back.
And you could do the release valve the same way, only the spring would tighten.
Seems like small jacks are less than $20 at China Freight.
Re: Well yea, That helps.
Of course, I'm not suggesting that anyone cannibalize a $300 mobile base to make this vise. I just thought the mechanism that Steve Gass uses was ingenious and elegant enough that someone might adapt it to the carving vise, especially given the quality of SawStop documentation. If you're planning to make one commercially, you would be wise to closely investigate his long list of patents. ;^J
Oh, and a 16 lb. bowling ball doesn't have much, if any, cork in the core, but lighter balls have a proportionally larger light weight core.
