Wax over Danish oil
Wax over Danish oil
Wax over Danish oil
Bradkansas
I just finished rubbing three coats of Danish oil into a newly made black walnut box. How long should I wait before waxing and buffing?
Re: Wax over Danish oil
Howard Acheson
Three to four weeks will be required for the Danish Oil to be fully cured. Before it's cured, it will be off-gasing which will keep the wax from getting fully hard.
Consider not waxing at all. Danish Oil is intended to be a complete finishing system. The varnish component in the mixture makes Danish Oil a fairly durable and long lasting finish. Waxing is really not required.
Jerry Gibbs
I agree with Howard and would add that you should finish a scrap with the same schedule and wax the scrap.
Clint Searl
Clint Searl
Waxing ain't gonna do anything to give the box some life. Better to top the cured oil with a film finish in the desired sheen to give it some sparkle.
Beg to disagree
john Veerkamp
A good wax like Renaissance Wax gives finished pieces a feel that is unmatched. Wood working is as tactile a medium as textiles or ceramics.
Re: Beg to disagree
Bradkansas
Some really good information. Thanks to all. I agree with John. Wax gives a softness and appealing sheen to most wood. I mostly make craftsman tables strictly following Stickley's techniques, quarter-sawn white oak, fumed, shellacked, waxed with Johnson floor wax. Once the wax is buffed, the tables come to life with a most compelling sheen and sensual feel.
Re: Beg to disagree
Tony - Memphis
I like wax too. I wax almost everything I build. I usually only wait a few days. I have waited less and couldn't tell a difference. For reference, I use Minwax and the Ren. mentioned above.
Tony
Re: Beg to disagree
Keith Newton
I'm not up on the Renaissance Wax, to know if it comes in dark colors, but if you didn't stain the walnut somewhere along the way, it will eventually fade down to the medium brown, loosing any darker or red tone streaks.
I have about 1/2 gallon of Watco Walnut cream wax, which does a great job of filling the open pores of the early growth, turning them to burnt umber, which will really help even while it is new, but especially after the fading. It is a little easier to use than a paste grain filler on the front end.
Re: Beg to disagree
bradkansas
Well, I put on a couple applications of Johnson paste floor wax primarily because the odor of the Danish Oil was too strong for in the house. The wax not only blocked the aroma of the DO but gave the walnut that subtle sheen and silky feel.
Re: Beg to disagree
Bradkansas
I experimented today putting several rubbed-on coats of orange shellac, about a one-pound cut. I make my own shellac. After the shellac was dry, I steel wooled it (0000) to remove the gloss and applied several coats of Johnson Paste Floor Wax. The result was striking. The grain was brighter not as somber as walnut can be. The dark and light parts of the grain were much more accented in proportion to each other. I'll go with the shellac and wax now for the rest of the box order.
Try it!
Brad
