opinions please Harbor Freight sliding compound mi
ken chase
I've read some good revues of this model 69684 from Harbor Freight but would appreciate
some input from members of this board before I make a purchase.
On sale for $129.00
Thanks
Ken
Re: opinions please Harbor Freight sliding compound mi
Steve Schoene
If your purpose is framing I suspect it will work OK, depending on the size of your project. For fine furniture not so much.
Re: Agree
I have purchased a few items from HF. IMHO they are a good buy for cheap (normally one project) use. However, I doubt you would be happy with the accuracy of any of their electrical tools for furniture building. The equipment I have looked at in their stores show pretty rough finishes and do not look like they would be very accurate or repeatable. I have looked at several items - haven't purchased many except a few hand tools (prybars, punches, odd items etc.). I have purchased a tile saw, works ok, threw away the "guide" and some other parts as they were useless. Bought a chain saw sharpener - does work but had to modify to hold chain down and not very accurate. Bought a pin nailer, worked for a while, had to repair - on my replace list! If I were looking to purchase a CMS, I would much rather find a used DeWalt, or other brand name, used than purchase a new HF. These are often listed on Craigs list in my area and are in the price range of a new HF.
Re: Agree
Basil
I bought the small sliding compound miter saw for $79.99. I've used it very little but works OK for what I wanted, a chop saw.
Had the same experience with their chain saw sharpener. It does a good job on chains but I'd have to write a book to describe in words how I get it to do that.
Keith Newton
Ken, I have not looked very closely at those saws, but here is how I would approach it. If they have one on display, I would pull it all the way out to the end of it's travel. Then grab the blade down where the cut would be made if the wood were there, then just push it around side to side, or feel for rotation in all the joints.
Then go to another supplier that has several other higher brands on display and compare the feel.
There are certain things that they make, which seem to be pretty good, especially as cheap as they are. But some or just horrible. I think I bought one of their plunge routers once, but gave it away about a month later.
BilWil
Bought one for cement siding. It was fine for most of the job, but was getting a bit sloppy near the end. I bought a reconditioned Bosch and have used it on three jobs and no problems.
waroland
I have used one on several volunteer projects and I would only use one for framing.
