OT - DishNet???
OT - DishNet???
OT - DishNet???
Ray - Middletown, IN
Anyone using it? Worth it? Dishnet seems to be about the only alternative I have in this location. This Verizon cell connection (or lack of) just isn't cutting it. Seriously considering just dropping internet service, it's that bad. Comcast still wants $1500 to install cable, and that is not happening. Nor am I going back to dialup, last time I had that here my average connection was about 22k, a joke nowdays but about the same as my Verizon connection. I seem to live in a black hole out here.
Ray
Re: OT - DishNet???
Re: OT - DishNet???
Paul Cates - Henderson, KY
Ray,
Do you know the distance to the nearest Verizon tower? Do you know your rssi and db levels? Adding an antenna and if needed, a signal amplifier may be all you need to do.
I cannot get cable or DSL where I live, so I ran conduit and cable to an outdoor antenna, added an amp to boost a very weak signal and hooked it up to a Verizon mifi. It works very well.
There is no fixed-point wireless isp in your area?
Re: OT - DishNet???
Re: OT - DishNet???
john Veerkamp
Gee Ray,
I have high speed dial up. 46K on this connection. I'm not ready to shell out for satellite. They are iffy at times. Maybe some day the information super hiway will get to rural America. And I'm only 40 miles from Kansas City.
Re: OT - DishNet???
About 6 mi as a crow flies, but,
there are several woodlots between here and there. The other issue with Verizon is the 5gb monthly limit, so even if I could get a good signal the data limit gets in the way.
I have had a couple of guys out here with fixed point systems but they could not "see" their systems from here.
I can get a really good AT&T signal here but data limits kill that one.
I have some projects coming up this spring that will require a better connection and more data usage. Probably will have to live at Panera, or set up shop in their parking lot ;)
Ray
Re: OT - DishNet???
Re: OT - DishNet???
I'm only 3 mi from town and can't get a reasonable signal. And the dropped connections drive me crazy, I have had to reconnect 8 times just to post these two responses. Ridiculous Now 9, make that 10
Ray
Re: OT - DishNet???
Re: AT&T
Yonak
AT&T has a deal now where you can get 10gb for $140. That covers two iphones and an ipad, and I use one of the iphones for internet for my computer.
Re: OT - DishNet???
Re: OT - DishNet???
Kevin French
We have DSL now and looked at Dishnet, it didn't work for us as we don't have cable for the TV. We watch 'tv' over the internet, Dishnet won't give us enough Stream time/month.
Re: OT - DishNet???
Jason Roehl in Lafayette, IN
On cable...
Have you discussed any sort of contract with Comcast for them to waive the installation cost? If you say that you're a business (and have a tax ID or other docs to show you are a business), and are willing to sign a 2 or 3 year contract for business-class service, they may write off the installation. They ran a line down our church's road because they were able to sign up 3 customers for 2 or 3 years each. Our part of the installation they wrote off was something like $23,000.
I can't say I'm a huge fan of Comcast overall, but their service here has been first-rate--the number of power outages to cable outages is about 20 to 1, and I get excellent transfer speeds. I was looking forward to the fact that MetroNet is working in town to run fiber to homes, but I just looked at their price structure, and they aren't really any better. Sure, it would be a somewhat higher speed (30/15 claimed vs. 28/5 measured), but it's about the same money, and it's a smaller company that doesn't have as many resources to deal with outage and technical issues quickly.
Jason
Re: OT - DishNet???
Re: About 6 mi as a crow flies, but,  *LINK*
If you haven't tested it, an indoor antenna could help quite a bit. An outdoor antenna with a high-gain yagi antenna plus an amp is the next step, but that is time, effort, and $. If you decide to try the indoor antenna with Verizon, you can get 20 gigs per month for $69.95 with no contract from Millenicom. That is for a mifi only without a cell plan. Although they won't tell you, Millenicom is a Verizon and Sprint reseller, depending on the plan. I'll be glad to help further via email or phone if I can.
http://www.millenicom.com
Re: OT - DishNet???
Used to have Hughesnet
John E. in SC
I used to have hughesnet satellite. Hated it. Not sure how it compares to dish, but I expect expect it would be similar. It was very expensive, about $70 a month if I recall, slow enough to make some websites unusable. The biggest problem, however, was the limit on how much data you could upload / download in a 24 hour period (called the "fair usage protocol", or something like that). Wasn't a big problem when just recreational surfing the net, but if you tried downloading a song or video, or even update a program, you would easily go over your limit, and then it would knock you down to worse-than-dial-up speed for 24 hours. Fortunately, our neighborhood had a few retired folks with lots of free time and they lobbied the phone company enough that we eventually got DSL, which is a thousand times better for a third the price.
Re: OT - DishNet???
Thanks, I will definitely look into that. I have tried an indoor antenna but to no avail. I looked at the outdoor stuff but that is all to this point.
Ray
Re: OT - DishNet???
Re: On cable...
Had not thought of the business aspect. I have talked to them several times with the same results. You would think that with the number of people dropping their service they would be more open. I guess they are more interested in buying other providers to gain more customers.
Ray
Re: OT - DishNet???
DishNet is HughesNet
And my fear is that the all of the negatives came with the purchase. Hughes had/has a horrible reputation for service.
Ray
Re: OT - DishNet???
Bummer
According to their website LTE is not available here.
Ray
Re: OT - DishNet???
Jack Guzman from Maine
Re: OT - DishNet???
I got my internet from direct tv's version.Satellite internet is somewhat limited but it works. I have had it for a couple years now and it works for me.---Jack
