help upgrading artist easel
ken chase
Instead of manually loosening a knob and sliding my canvas I want to convert it to
a weight pulley system. I would like to upload a front and rear view of the easel but don't know
if I can as the photo is on my desktop not on the internet. It's probably simple but I have no
knowledge of pulleys and the hardware they require.
Thanks
Ken
p.s. If there is a way to upload the photo please advise how.
Re: help upgrading artist easel
William Duffield
It's a three step process. First, you need to establish a WoodCentral Profile. Bill Houghton explains that here:
http://www.woodcentral.com/woodworking/forum/archives.pl?pro=search;pmd=sread;srchid=3384rxNQ6gEnJsjfztK1394041394;spage=1;sanc=463997;sbid=1001;md=read;id=463997#m_463997
Second, unless it's already less than 100kB, you need to you need to edit the pic to make a copy that is small enough that the WoodCentral system will accept it. Your photo editor may also need to convert it to a .jpg file if it is in some other format.
This process is explained in the WoodCentral FAQs. You will find a link to the FAQs in the linked posting below.
Third, you need to upload it to WoodCentral while you are posting the message. Bill explains that process here:
http://www.woodcentral.com/woodworking/forum/handtools.pl?pro=search;pmd=sread;srchid=3384rxNQ6gEnJsjfztK1394041394;spage=1;sanc=472107;sbid=3000;md=read;id=472107#m_472107
Hank Knight
Ken,
My daughter is a painter. Several years ago I built her a counterweighted easel using 80-20 extruded aluminum for the superstructure and Schaffer Marine sailboat blocks for the running gear for the counterweight system. I made the base and the adjustable canvas frame from white oak. It has been a great success - she loves it. I don't know if I can help you with your easel, but I will be happy to give you any thoughts I have. Post photos of your easel using William's instructions, and we'll talk.
Hank
Re: help upgrading artist easel *LINK*
Tony - Memphis
I built an easel for my wife last year. I found this site with a plan that looked pretty good. He designed it to use hardware store parts. I dressed it up a bit, but his design is pretty good. You might can get an idea of how the counterweight system works from the pictures. I got all of the parts at Lowe's. My wife loves it and it works very well. Very simple too. I had started workig on my own design, but when I found his site, I figured he is an artist and had already worked out the bugs. I played with the weight until the balance was pretty good. My wife is 4'11 and not very strong, but she is able to move the frame up and down very easily. I had to amke some adjustments in the clamps after the wood moved around a bit. I just finsihed making her a mahl stick - I used two strips of metal attached to wood (for top and bottom of canvas) and the stick has magnets embedded in it. She really likes it.
Tony
http://www.artisteaselplans.com/arteasel/
