Metal Bracket for Tripod Pedestal Table
Joe Burke
I can only take a stab at describing this, so here goes.
I've repaired a pedestal table. Three legs in,what I believe is, typical Duncan Phyfe, splayed leg, style. The legs did exactly what you'd expect them to do when years of downward pressure had been applied. They broke loose from the pedestal. They'd been doweled to the pedestal so I cleaned them up, enlarged the dowel holes and put them back. It was way more complicated than that, but let's keep it simple.
I've seen metal brackets in the past designed to prevent the very thing that happened to this table. The bracket would be round ... smaller than the dia. of the pedestal base ... and have 3 wings, if you will, at 120 degrees around the perimeter that would line up with the legs and actually lap over the legs. The wings would be screwed to the legs and the center of the bracket would be screwed to the center of the pedestal. This would, in effect tie all the legs together and resist the down force that pulls the legs from the pedestal.
If no one gets this I could draw a picture, but I'm hoping someone will know what I'm talking about.
What would this be called? I thought it was called a spider? I know doggone well I've seen them in catalogs before, but I can't find anything anywhere about one of these things. I've Google searched everything I can think of using all the verbage I can muster. So far nothing. What is this thing?
I already know I'll have to make what I want and that's not a problem. I'm just frustrated at my inability to find this wretched thing!
Somebody help ... just a little.
