Veritas - Innovation in Tools
cutting boards- 2 different cherries
The darker board was made from cherry that grew at lower elevation here in E. TN. The lighter is northern cherry. These differences in color are characteristic of cherry from these two locations.
The pattern was created by slicing off 1 " pieces from 8/4 cherry plank. The short edge of each piece is consecutively numbered as they are sliced. (Number the edge that will be the outside edge of the board so you can see the numbers in the next step) Line up the even numbered pieces in one column to make a rectangle(one side of the board) and the odd in another. Glue the pieces in each column together and after the glue is dry glue the columns together. Round edges, sand and slather in any vegetable oil.
These boards will be door prizes at some classes I am teaching in Burrr, freeze! Chicago. I have crocus blooming here at the house.
Re: cutting boards- 2 different cherries
Re: 2 different cherries
Yonak
Nice door prizes ! ..Then the overall sizes are, like, 12" X 9" X 1" ?
Do you notice a marked difference in density between northern and southern cherry ? Cherry here in Georgia seems to be darker and less dense than Pennsylvania cherry.
Better take your galoshes with you...
hope you're not traveling this weekend!
What are you teaching?
GolfSteve in Calgary
Hi Bill, are you teaching woodworking related stuff? I saw your Chicago post earlier. Turns out I'll be in Chicago next week also (working). Not sure if I'll have much free time, but I'm going to see if I can get to the Lloyd Wright house and a classical guitar shop.
Nice cutting boards.
Steven
