redoing workbench dog holes
I built a workbench using an Oak solid core door about 10 years ago. I drilled 3/4" round holes in the top to be used with Lee Valley bench dogs and Hold fasts. The hold fasts have elongated several of the holes and they no longer work when the holdfasts are hammered down. I need to fix that and though I'd ask opinions.
the simplest solution is to simply drill new holes in new locations. The second solution is to drill them to a larger size, possibly with 2 sizes of drills and then fill the holes with T shaped round dowels and then redrill. The third solution is to use my Bung Hole reamer to enlarge the holes, turn tapered plugs to fit and then redrill these.
any other solutions or which of the 3 sounds the best.
Re: redoing workbench dog holes
Bart Goldberg
Bart Goldberg
Interesting problem - Heres an odd ball solution I thought of. Get some metal (brass or copper?) tubing that has a 3/4inch interior diameter and cut it up into inserts to the existing holes and to a length slightly shorter than the existing holes are deep. Drill out the existing holes to the size of the exterior diameter of the tubing and epoxy the inserts in place. I'd set them slightly below the surface to keep them from getting hit by any other tools.
Bart
I don't understand why you would go to the extra work of drilling and turning T-shaped plugs. It seems like straight plugs would hold fine, as long as the diameter of the plug and the diameter of the newly drilled hole are a snug fit. To keep from having to do it all over again in another ten years, I would choose hard maple for the plugs instead of oak.
Off on a tangent, I have a Work-Mate whose top I replaced 4 or 5 years ago with 1-7/8" thick hard maple. When I pulled it out last week to take to a woodworking show, I found out that the top and the 3/4" ø dog holes had finally shrunk enough that my Veritas bench dogs would no longer fit. I'm going to have to redrill the dog holes. The 8/4 maple boards I used to make the new top had been acclimating in my shop for a dozen years, so why now? Gramercy holdfasts still work fine, and I used those to secure a mini-lathe to the top of the workmutt for the show.
Interesting Bart, I'll consider that
It would be interesting to see how the metal deforms over the years. I would assume I would not want to make them out of steel but use brass or copper instead. I could knurl the outside diameter to make the epoxy hold better.
blame global warming
Why now?
Because they can.
