Box/Veneer Cutting Question
Tony - Memphis
I am working on a plan for a tea box for my wife. The box will be veneered. I plan on adding a small corner strip to make a nice neat durable corner. Just wondering if anybody has done this and has any tips on cutting the rabbet for the corner strips? My concern is chipping the veneer. Looked at various techniques, but thought I'd ask. The box is small and the rabbets will only be 1/8", so not much material to remove. Box substrate will be 1/2" mdf. Not sure, but the veneer will probably be waterfal bubinga on the outside and satinwood on the inside. Top will be something a little fancier - maybe 4 way match with inlay and crossbanding - still thinking.
Thanks,
Tony
Re: Box/Veneer Cutting Question
any different than cock beading?
Never had any problem cutting the rabbit for cock beading. It will be essential to have the veneer glued down well.
Paul in NJ
Score with a knife and square, saw with a fine tooth saw, and cleanup with a paring chisel. Why not use real wood or BB ply instead of crappy mdf, hate the dust from that stuff.
Paul Dzioba
Tony - Memphis
Thanks. Actually, I find mdf to be an excellent substrate. I've used it for many veneered projects.
Such as this crappy table...
I used a router on a trammel with a spiral bit to trim the top after I glued the banding down. That worked pretty well. No chipout to speak of. I'l probably do some test runs.
Or this one
Trimmed with a veneer saw.
Wow.  Nice veneering work.
question
How will you fasten the corners of this box together? If mitered, does a MDF miter glue better than real wood?
Joe Burke
I'm not sure if I'm on the right track here, but I've used a cutting gauge to score a line prior to cutting a rabbet on the router table. It goes without saying that careful set up is required, but it does eliminate most chance of chip out and produces a clean edge.
Same principle as using a knife and square but more accurate IMHO.
Sorry to state the obvious.
Pretty work in the pics too.
Tony - Memphis
Thanks. That's a technique I had considered. I read an article (FWW) that described something like this and the author cut within a hair of the lin and finished it with a chisel. I'm going to try and make some test panels this weekend. I'd hate to get the box all glued up and veneered and hen mess it up! That would ruin my day! I've got to check my inventory of veneer and see what I have left. This is for my wife's birthday in March - holy cow! - that's coming quick. May not make it! Oh well, her Christmas present was finished in March or April last year, so.....
Tony
