Samantha's dresser 10- sawing veneer problems
Sams cabinet- sawing veneer
The goal was to saw veneer for drawer fronts from some walnut crotch wood. I have never sawed veneer before and encountered new problems doing so.
Pictures 1 and 2 show the arrangement I use for resawing. For example, in this case I am splitting 5/4 lumber to make 7/16” drawer sides. The saw is an old repainted 20 “ Delta. The large wheels are compatible with a thicker, and hence stiffer, blade. The large gullets on this blade don’t clog with sawdust when resawing wide boards. Clogged gullets lead to blade wander. Smaller wheels work a thick blade too much, fatigue it and then it breaks. I have never broken a blade on this saw. The large table on this saw, 20 x 24” also makes resawing , or any sawing, easier.
When I sawed veneer from a piece of crotch wood two problems were encountered. First, the blade shown does not quite leave a surface smooth enough to directly glue. Second, there was tension in the crotch wood and it moved each time I took a 1/16” slice from it. As a result I was using up about 3/16” of wood for each slice of veneer I obtained- 1/16” for veneer, 1/16” for kerf and 1/16” or more to smooth and re-flatten the remains. This approach was wasteful of the nice crotch wood.
PIC 3 and 4
A friend has a band saw fitted with a variable pitch carbide resaw blade. This blade leaves a surface that can be glued to the substrate without further smoothing.
I solved the instability problem by gluing all the crotch pieces together into one billet and backed it with some 8/4 oak as shown in Picture 5. The bottom edge was jointed square, then shellaced and waxed for easy sliding. We sawed 20 pieces of veneer from this billet with no re-flattening required during the process.
