Pedestal Technique Take 2
Alan Young
I am planning out work for a pedestal Table:
Here are the profile requirements:
Will this lamination scheme work? The outer circle on top is the final outside diameter, the middle circle is the cut-in, and the furthest inward circle is the approximate diameter of the open space from the laminations-This yields a 3/8 inch thick wall at the cut section.I'd like to avoid using solid lumber all the way through if possible. After gluing these boards up I would cap each end with a plywood plate and center the piece in the lathe for turning...Any pitfalls to this plan? Thanks, Alan
