Kitchen Cabinet question
Butch...Mn
I am heading into uncharted territory for myself. I am currently making kitchen cabinets that will be used in my farm shop. We decided it would be nice to have a little nicer area for when we make sausages and smoked meats. Cabinets are something I have never made before and would like to get some advice from the seasoned pros who hang out here. I would like to use self/soft closing drawer hardware. My cabinets will accept 22" slides as the cab is 24" overall deep which includes the 3/4" face frame 1/4" back. What are the pros and cons of side vrs bottom mount hardware and what are the preferred brands and or models within those brands. Is one style easier to mount than another and where is a good place to buy? I look forward to your replies and helpful advice.
Re: Kitchen Cabinet question
Keith Newton
I think the Blum bottom mount are the best. You are only making it harder by using face-frames though.
"Old fashioned" approach
I use genuine (not made in China imitations) Accuride full extension side mounted slides for this application. There is noting apt to wear out or break, they hold anything you are likely to put in the drawer and they work smoothly for decades. The advantage of soft, self closing escapes me.
For some reason Accuride slides are cheaper at places that cater to the professional cabinet making trade that they are at our typical woodworking catalog order tool and supply places.
don stephan
Make one cabinet as a learning experience before beginning production. Use only top of the line hardware. And price out "regulalr" vs self close, you may be in for a shock.
Gary Smyth
Brands that have served me well are Hafele, Accuride, Blum
Buy full extension drawer slides.
Get heavy duty slides (model numbers vary according to weight) that have no rattle or lightweight stamped frame member use steel ball bearings. All my slides are 75lb for small and 150lb for large
Go to a cabinet shop to find their source. Stay away from consumer catalogs for multiple slides in same length.
If being used with/for food, I’d purchase prefinished ply for interior surfaces
Make sure that you have space. Space for sheet goods, a place for any existing cabinets if you intend to save them, space to cut and glue up several cabinets at once, space for jigs, assembly carts, tools, and clamps not in use, space for finishing, space for stockpiling the cabinets prior to the finish and install. You will need a lot of space.
I prefer side mounted hardware as I don’t like the loss of depth of the drawer for bottom mounts.
For any drawer over 6” in height I increase the thickness of the bottom beyond ¼”
I have built using a ¼” back, but I prefer 3 /8 or even ½ “ for screwing into. That is my preference however
I prefer drawers over doors. More to do at the start, but better for me in the long run.
Make consideration for plumbing, cooking/heating, and power in the grand scheme
If specialized hardware and/or top surfaces other than slides, order early
This is a big project. preplan and set a reasonable schedule.
Best wishes
Ralph Lipeles
I would also think about cabinet material. I would use something prefinished and use a sealant between joint sorfaces to facilitate cleaning.
Re: "Old fashioned" approach
Thomas S Stockton
Bill
One of the advantages of self closing hinges is that clients think they are really cool and happy clients make my life much easier.
I use the blum undermounts, they are easier to install and a little more forgiving that accuride side mounts. They seem intimidating at first but are actually really straight forward. For cabinet work I buy pre made dovetail drawers and have them machined for the hardware.
The accuride self closing side mount hinges are a complete pain to work with. I have had to replace all the ones I have installed.
Tom
accuride self closing full extension slides
GolfSteve in Calgary
"The accuride self closing side mount hinges are a complete pain to work with. I have had to replace all the ones I have installed. "
That's interesting. I've only used them once for a built-in closet, and after a while they are not closing very well - you have to push the drawers hard to close the final inch or two. During installation they seemed quite sensitive to alignment. I assume that several years later the alignment is off a bit, but I've been too lazy/busy to fix them.
That is what I figured......
......namely they seem to be a "cool" feature to some. And the price of cool is a more complex mechanism subject to failure. I will continue to endure the burden of manually closing drawers employing ball bearings rolling in a track that will last a life time of trouble-free operation.
