Re: Watco vs Deft Danish Oil
Harry Ludke
I used to use Watco Danish Oil all the time. But, when I started building some Hal Taylor rocking chairs, he recommended Deft Danish Oil. I now much prefer the Deft Danish Oil. It seems to have quite a bit more varnish in it's mixture and leaves a very nice satin finish.The trick is to apply the first coat and really soak it, leaving no apparent dry spots. After 15 minutes I wipe it dry with paper towels repeating as needed until the oil stops bleeding out of the wood. Let it dry overnight and apply a second coat in the same manner. It will take much less Danish Oil and bleed less. Again let it dry overnight, rub out the nubs with a 1500 grit Micro Mesh sanding pad. Apply Carnuba or Butchers wax. Stand back and admire your work!
Fool proof system leaving a SMOOTH satiny finish that seems to hold up very well to daily use.
