Thanks Jason, and another question.
Tim Greif - West of Chicago
Thanks for the tip on using a paint pad for the WB poly on a large tabletop. I'm going to try it.
Another question - recently you indicated that a contractor friend of yours used a technique at drywall corners with clips to avoid callbacks. I have a different issue with drywall that you might have some advice on as a painter having seen just about all kinds of drywall splits. I have a summer home that has quite a number of ceiling tape joints that have split. Not at the edges, but right in the middle of the ceiling. I keep the place at 50 degrees during the winter which I've been told helps with drywall issues. What's the proper fix for this and how does one go about preventing it from happening in the future?
I have cathedral ceilings and am well aware of the cracks that appear at the corners where three different angles meet. I'm more worried about the seams in the middle of the field. I would have asked you this privately in an email but figured others may also be interested in response. If anyone else has anything to offer, I'd love to hear it.
Thanks,
Tim
Re: Thanks Jason, and another question.
Jason Roehl in Lafayette, IN
When you say the tape joint has split, did the tape itself split, or did the joint compound split next to the tape? Is the tape loose at all?
I can't say I have any real advice on prevention. With cathedral ceilings, it's possible that you still have a large temperature swing from the 50ºF in the winter to 80º or 90ºF in the summer (it's amazing how much temperature differential there can be with taller ceilings). That is, enough of a swing to cause significant movement. The same may be true of moisture.
Jason
