The shrinking Inch
don stephan
Needed to buy a roll of blue masking tape this morning. A one inch wide roll is now .94"/24mm wide, a 3/4" wide roll is now .7"/18mm. Bet the price didn't drop with the switch to the narrower roll.
The shrinking Inch
don stephan
Re: The shrinking Inch
Jim in River Oaks, Ont.
I can remember when a dollar was A Dollar.....:-)
Take care,
Jim
George
We are the kind of guys that take a micrometer to the box store.
mdclor
It's a metric world. There are only 3 countries in the world that aren't using metric and we happen to be one of them. You really can't expect manufacturers to cater to 5% of the world's population, can you?
I'm curious...
John in NM
Why does it matter? To me there is narrow tape, wider tape, and really wide tape. I suspect Merle has it right, the change is more for the advantage of metric in international markets than for cost savings.
Now with plywood, I'm right there with you, cursing all those odd, inconvenient, and slightly less than they ought to be measurements.
Smatta Witchas?
You don't like sheet goods that ooze U-F gas and then delaminate when the gas is gone?
You don't like having to buy new router bits to make tight fits with the new plywood dimensions?
I suppose next you're going to tell us you don't appreciate how much skill and dedication goes into cutting those face veneers at 1/10th of a millimeter thick, right?
Sheesh, some people . . .
That's why I like baltic birch...
John in NM
I just figure it's metric and don't get all hot and bothered about the odd thickness
Don Evans
Yes, BUT 1 inch is 25.4mm not 24mm his point seems valid to me that the 1" wide roll has been changed in width.
I don't think it has anything to do with metric sizes etc.
More seriously if they wanted to really cheat they could just put 30 ft of tape on what is claimed to be 36 feet long roll.
How many of them has anyone check to see if they have the right length on the roll?
Don
I saw one of those How do they do that shows on making tape. they make it in rolls that are about six or eight feet wide and then slice it down to whatever width they sell. I bet if you knew the width of the original giant roll you would find that 24 mm gives them at least one more roll than 25.4 mm. We don't really miss the mm and they get another roll "free".
Re: That's why I like baltic birch...
Bruce, a MN Galoot
Even the so-called "baltic birch" I get from the local borg isn't consistent in thickness, metric or not. Of course, that could be because it's supplied by the lowest bidder.
John in NM
Some variation is to be expected with any plywood, though if they were selling an honest sheet you'd expect a few to be slightly over rather than all slightly under size.
I'm surprised your local box store carries baltic birch. I have to go to a real yard to get it.
Bruce, a MN Galoot
I suspect it's not real Baltic Birch, just labeled that. It comes in 4 X 8 sheets, so that should be a good tip off.
Last Baltic Birch I bought was from a "supposedly" higher end supplier in 4 X 4 sheet. When I set up the dado head on my saw I ran a sample board about a foot long to check fit, I was pretty annoyed when I found the BB thickness varied enough that the dado cut went from loose to not able to fit along the sheet edge. I measured the thickness and it varied .015" or more. I ended up taking a "back cut" off the sheet (Ellis has recommended this in the past) and narrowing the dado in order to achieve the fit I wanted.
John in NM
ya got snookered.... baltic birch comes in 5x5 sheets. No idea why it's not 150 cm (about 59") but it's 60" square.
I've never noticed terribly inconsistent thicknesses with it, or shop birch either for that matter. I was joking that the "just under 1/2" doesn't bug me if I think it's 12mm - it's well over 12mm though, so that doesn't really work, just being kind of ironic.
Re: Goofed in my post BB was 5'X5'
