THE WOODRAT IS BACK!
vertical v. horizontal wood storage
Ronster
I have some new shed space at my new shop that I need to outfit for lumber storage (mostly rough as long as I can still buy it). Maybe less than 1000 bf of hardwoods is what I'll maintain in storage. I've only purchased dry lumber in the past, and I've used stickered horizontal storage, with seemingly good results as I give it time to acclimate before dimensioning.
Vertical storage is tempting however, as it's so much easier to sort thru to find suitable stock for the project of the moment.
Does vertical fail to encourage or maintain straightness for already dry stock?????
This is an important question for me. Thanks.
ron
Re: vertical v. horizontal wood storage
Keith Newton
You wrote. "I've only purchased dry lumber in the past, and I've used stickered horizontal storage, with seemingly good results as I give it time to acclimate before dimensioning." If you are buying dry lumber, you don't need to be sticking it, especially out of doors. If it was KD, you would do better to stack dead, then wrap it with plastic, if it is stored in the outdoor atmosphere.
As for keeping and sorting KD inside the shop, I do like the ease of sorting to choose just the right board with vertical storage. And if it is not leaning too much, you shouldn't have any worry about warping.
del schisler
in the old days when they would saw wood they would vert. stack and hang wood, i cut lot's of wood and i vert stood it up and also hang some wide walnut and never had any problum's , i belive it will dry better being the wood is fibers running long way of the board, gravity pull's the moister down ? i would vert. stack as streight as i could . if it is kiln dryed you will not have any problum's , not that i am garantee tho
An alternative opinion
I have never seen lumber stored in a vertical arrangement, and I have seen a LOT of lumber being stored. I doubt all these companies and shops got it wrong.
I don't see the convenience of a vertical stack, unless it is a very small amount of lumber and the need is to save floor storage space. The picking criteria of first importance will be width. Lumber in a rack reveals it widths at a glance. As an example, a friend called yesterday needing a piece of walnut 8" wide. Could I help? In 10 seconds I was able to answer the question. There is 500 bdft stored in that rack. Even if he wants the bottom board it will be but a few minutes to empty it onto horses and then reload. More probable we will only need to empty a few layers to find something that will work for him. Hardly an onerous task.
If I am starting a project and it will be from say cherry, I will take a look at most everything in the rack. My racks are set up to accommodate 500 bd ft of 12' lumber. That is less than 15 layers of lumber. It is little effort to slide it from the rack onto a pair of horses to examine it and back into the rack. There is little lifting involved. The effort and convenience to move 500 bdft stored vertical seems greater, at least for longer lumber.
One More Opinion
Joe Burke
I really think this is a space issue. I have a vertical storage rack, and I as I thought about it just now I realized my decision was based entirely upon space. I just don't have the space to store lumber flat and unstack it to pick pieces. On the other hand, I can store between 500-1000 bdft in my vertical rack and sort through it fairly easily. Life is full of trade offs.
I'm sure boards could be stored poorly and have them warp as a result. However, I've come to suspect that a board is gonna do what it's gonna do regardless. I may be way off with that assertion, but if you start off with dead flat, straight lumber it's more likely to stay that way regardless of how it's stored. Just as if you start out with lumber that's bowed, twisted and cupped it's likely to stay that way too. All of this provided nothing is being done that's way out in left field. I've never been able to take a board with a terrible bow, for instance, and straighten it out with weight or clamps over time. Of course, I could be wrong, and it'll be interesting to hear about it.
For most of the places storing a lot of lumber the forklift is king. Not all mind you, but most. Everything is stored flat and can be easily handled by one person. They have ample space and machinery so they act accordingly.
I have seen a couple of big suppliers who stored some of their stock vertically because it allowed customers to sort through on their own a bit more easily.
It's whatever will work for you and your space.
I have to agree with Bill (seems like I often do that). I have a 30' X 10' wide X 8' high (with knee walls) "upstairs" storage for most of my lumber. Much was purchased at Amish estate sales - well air dried. When brought home I stickered it and after a few weeks/months removed the stickers when I needed more space.
I have stored (short term) quite a bit of White Oak (this was KD and purchased for the project from a local Saw mill) when we were making and installing all of the trim for my youngest son's house remodeling project. At that time we found it far harder to sort the boards for width / length - ended up stacking on the floor horizontally. Just a lot easier to shift a pile than lifting and moving a vertical stack. I doubt you would have any warping issues as long as it wasn't leaning too far, but if you have the space I definitely would stack horizontally.
Re: An alternative opinion
Yonak
While I agree about storing horizontally, Bill, if you can unstack and re-stack 500 bf in a few minutes I am eternally envious.
the key...
is to not lift it. I set up horses in front of rack and slide the pieces from rack to horses, then back to rack. Well, the second key is to be able to tightly pack the rack by deft movement on the end of the board being slide into the rack. After a few tens of thousand feet one gets good at it. It is entertaining to watch a new employee on a lumber yard struggle to make nice stacks.
I know a guy who made up this plan... *LINK*
Grant in Iowa
Ronster,
I built one of these several years ago, then moved it to my new shop, added a second unit of similar design only A-frame with storage on each side, then added a third one as my lumber collection grew. The cost has risen slightly for materials, but still relatively inexpensive.
Make sure if you build an a-frame unit that you stiffen the unit by adding some OSB or similar to prevent the unit from racking. Happy to share more details if necessary.
One benefit is that you can sticker lumber on this design every 16" for drying.
FWIW,
Grant in Iowa
http://woodcentral.com/articles/shop/articles_794.shtml
Re: Can't see the forest for the trees
Tom
Of course most places opt for horizontal storage. But it doesn't seem to harm the wood either way. Most of my wood is stored vertically on my 125 acres.
I did pass a picture of George Nakashima in front of a large stickered pile, while I was trying to find this one...
del schisler
Bill i have had walnut like 15" wide x 12' long and lot's of different width and length, i have a old bldg with 20' high ceiling's what i did was hang them up with eye hook's in the ends and let them hang i guess 1/2 yr. they didn't bow or curl they stayed streight , i did the same with some butternut same rusults. i did a google search on vert stacking , lots of stuff to read here is just one paragraft
the google link
http://www.sawmillcreek.org/archive/index.php/t-43497.html?s=9bdfb1264aa5c7ebd61c0346b10c25d5
09-28-2006, 6:08 PM
Wood is usually stored vertiaclly here in Japan, I've seldom seen it stored horizontally.
I know of a guy that mills his own lumber and he advocates storing it vertically, I'll see if I can find a link to his homepage. He uses an "L" sticker to keep the board seperated.
Found it........... LINK (http://www.billswoodcreations.com/dry-wood.html)
Cheers!
Re: One More Opinion
Tony - Memphis
Same here. With no regard to considering what is best fo rthe wood, I store mine both ways. Just depends on where I have space. I don't have much! Never noticed that it made a difference.
Tony
It won't make a difference unless.......
So long as the wood is dry it will only change shape if it is put under stress, and standing on end is not stressful.
However, a bowed board mashed flat under a pile of straight stuff will be stressed and straighten some. A flat board piled horizontally on a support that is not flat may be stressed and can bow or twist.
Wood that is still drying is another matter. There is good reason that mills put sticks every 12 to 18" and pile lumber flat in tall stacks when drying it. If held flat it will remain flat after drying. Not held flat, tension created by differential shrinkage during drying will result in twists, cups, bows and crooks.
BobEva
I've never seen it stored horizontally, everyone I know stores it vertically as it's easy to flip through the stack without unstacking the entire pile to find the board you need. Just like at the lumberyard, around here they are all vertical. But I'm in SoCal so maybe we are just weird that way. We have more space to go up and less to go out.
Plus, vertical boards probably remind y'all...
...of surfboards.
Alan in Little Washington (NC)
Bill, I think you are looking at storing vertically the wrong way. Wood is often stacked "against a wall" by hackers like Nakashima, Maloof, Marks, Schleining, etc. especially if they are wide slabs, but the best way to stack planks vertically so you can see the edges of every piece, pull any board at any time to inspect both faces, have no empty space like need for horizontal rack shelf arms, etc. etc. is to stack the boards "soldier style" with the edges against the wall. The other not so small benefit is that it requires almost no structure or hardware since the floor supports 99% of the weight. Ceiling height is about the only consideration.
Nearly empty rack:
Half full:
Nearly full rack:
Non-starter:
Surfboards...maybe...for me...
Tom Dunlap
...vertical stacks remind me that the material came from trees. A lot of my lumber is live/wany edged so it looks very tree-like.
Right now most is horizontal. At another place it was vertical because I had tall ceilings and fewer square feet.
'Thumbing through' a vertical stack is much more pleasurable to me than shuffling horizontals.
Tom
Tom
Nice rack. I normally have my wood that I think I am going to use soon, vertically, if it is long. And I have some longer term stuff horizontally.
Re: It won't make a difference unless.......
Tom
Except with really thick planks, they hold themselves straight. I like to cut wood into large pieces so that I don't waste wood until the end purpose is in sight.
