Rockler band saw top molding
iew
The edge T molding on my Rockler band saw table is beginning to breakup. Rockler cannot supply the molding. It is 1 3/16 inches. Any ideas where to find? TIA
Re: Rockler band saw top molding
Why does a bandsaw table need edge moulding? I've used many bnadsaws from many manufacturers (e.g., Delta, Rikon, Jet, Laguna, Walker-Turner, Powermatic, etc.), and have never encountered one that had moulding on the edge of the table.
iew
This will explain it.
Re: Outwater Plastic
iew
They had a 5000 ft minimum order. Only need 6 ft. Thanks.
An MDF top? ugh! Aluminum I can understand, Cast Iron I can understand. Granite I can understand.
Instead of replacing the rubber bumper, you might consider sawing some thin strips of hardwood (hard maple comes immediately to mind - that's what I used on my first router table) and gluing them on. If you soak them in boiling water, thicker strips will make the bend easier. Any overhang can be taken down flush with a laminate trimmer, or file or block plane or card scraper.
Re: Rockler band saw top molding *LINK*
Bob Entwisle in NJ
Might give these folks a call, don't know if they'll cut you 6 feet or not, but there's a toll free number to call, so won't cost anything but your time to ask.
Bob in NJ
Tee Molding
