Found - might be of future interest
Gary Smyth
From the Smithsonian. Information relating to traumatic injury. Looking for a injectable fluid to stop bleeding.
"To meet this challenge, the company RevMedX has developed the patent-pending XStat—a syringe that, when injected directly into a gaping wound, creates a sealed barrier made up of tiny, pill-sized sponges. In tests on pigs, it took about 15 seconds for the device to bring a loss of blood to a halt."
"In their search for alternatives, they found that cellulose (wood pulp), with its super-absorbent properties, would be much more effective at stanching the difussive flow of blood.
“What's great about cellulose is that it's been around for decades and has good track record in the medical field," RevMedX vice president John Steinbaugh says. “But besides being sterile and safe to use, the big advantage with our version is that it can expand to 15 times its original size. So there's no need to apply pressure as it's already being applied on the inside as it expands."
Identifying a suitable material is one thing, figuring out a method for medical technicians to apply the dressing in a manner that's rapid, reliable and simple is another. For that, Steinbaugh credits students at Harvey Mudd College, who worked with RevMedX to fabricate a spongy material that’s coated with an antimicrobial clotting agent called chitosan. As the sponges soak up blood and expand within the wound, they clump together, becoming one firm mass that prevents excessive bleeding while similtaneously accelerating the clotting process. Addtionally, the sponges are individually marked with an "X" symbol that’s visible under x-rays, making it easy for surgeons to locate and remove them.
According to Steinbaugh, one pocket-sized applicator has the absorbent capacity of five large rolls of gauze. The company is also working on a slimmer version to handle cuts with narrow entry points and biodegradable sponges that gradually dissolve in the body. "If you can make the material absorbable by the body without any side effects, it makes things less complicated for the surgeon," he says, adding it would also be particularly effective for nosebleeds since the sponges could be left inside the cavity for several days.
Read more: http://www.smithsonianmag.com/innovation/injectable-bandage-can-stop-heavy-bleeding-15-seconds-180949723/#ixzz2tVrjj54o
Re: Found - might be of future interest
Chuck Hans
I would like to add that applying black pepper to a cut will stop bleeding it is very effective and I use it when I cant get a cut to stop bleeding
I have used Spider Webs for minor cuts when I was in the woods before. It is very effective, stopping bleeding almost immediately, and judging from the results - does not promote infection. It is an ancient technique used by Native Americans (My Great Grandmother was 100% Cherokee).
