I Phone Question
I Phone Question
I Phone Question
I have an I-phone 4S. Its in a Otter box. Lately it turns itself down or at least the ringer turns down at random. It creeps down. I have tried turning it off and back on to reboot it. Several times. I try to be consistent to turn it off before I put it in the belt clip.
I went back to the store (wireless carrier) where I got it but they said to take it to the Apple store. That's about 25 miles away and I have not made it.
Any suggestions? Its annoying to miss calls because it went silent.
Re: I Phone Question
Keith Newton
A couple of things I would try.
Go into settings, and turn vibrate ON in both places, so even if you don't hear it, you can feel it.
If you don't use the buttons on the edge to turn it up or down intentionally regularly, you can turn them off. After that, you'll have to go into settings and use the slider bar to change the volume.
Steve Kniffen
Open up the Otter case and make sure there's not some debris between the case and the volume buttons on the side. Also, check out the way you hold the phone. I found I was inadvertently turning down the volume for the ringers and for the speaker when I held it to my ear sometimes.
