Question on gluing up QSWO Legs
A friend wants me to build them a Desk with square tapered legs out of oak. I have plenty of 4/4 QSWO but no 8/4. Would it work well to glue Two layers of 4/4 together and taper them, then veneer the faces with the glue line to make the legs appear quarter sawn on all four sides? I think some people miter the corners and then glue up four quartered faces, but I am not sure I can manage the long miters.
Re: Question on gluing up QSWO Legs
Re: Question on gluing up QSWO Legs *LINK*
Bob Lang
Laminated and veneered was the Gustav Stickley method. Little brother Leopold developed the quadralinear method. In theory, the veneered legs might crack over time due to the QSWO moving more in thickness, but I'm starting to believe that the cracks I've seen in antiques are due to harsh environments (banished to the basement barn or attic).
If you're set up to machine a boat load of legs at a time, locking miters on the corners makes sense. For one-off pieces, lamination and veneering is a lot easier. I resaw my own veneers about 1/8" thick and bevel the edges back to the glue line. This is discussed in detail in my book, "Shop Drawings for Craftsman Furniture".
Bob Lang
more about the book
I'm with Bob on that but would suggest
Keith Newton
That you try to pick out some rift for the legs. If the annual rings run near 45* then you get the same pattern on all four faces. Plus, glue lines are less obvious on the rift pattern than either QS or plain. Save your QS for top, drawer fronts, and panels where it shows better.
Thanks and another question....
I have plenty of 12/4 poplar. What about making the legs out of poplar and veneering all four sides? Probably too fiddly but it might work.
Thanks for the ideas above. I had forgotten to consider rift sawn.
Re: Thanks and another question....
Bob Lang
How big are the legs? Poplar will let you skip the lamination step, but it might end up squirming around below the veneer, causing problems down the road. Rift grain will make a nice stable leg, but the look will be quite different.
Bob Lang
don stephan
If you want ray fleck on all four faces of the legs then I think you'll have to either make the mitered legs or use veneer. If ray fleck is not essential on the legs you might be able to laminate two pieces, then cut the leg blank out as a diamond so that the glue lines are on opposite edges of the leg, and will be invisible. This assumes two layers will give you the needed thickness with the diamond pattern.
Thanks, this is why I like Wood Central, yet another possibility. I will have to look at my stock and check out the chances of this working.
