Loctite Rant
Loctite Rant
Loctite Rant
jim Hoeller
I bought a dispenser of Loctite marine epoxy for a project that took about a year to begin. The epoxy is two part in a syringe type dispenser. After cutting the tips off, I tried to dispense some. The white material came out but the brown material did not (I don't know which is resin and which is hardener). I stuck a nail in the brown side, it went in and some material was on it when extracted. The plunger still would not push any out. I thought the age may be a factor and bought another one. Same problem. Sent an email to Loctite explaining the problem yesterday morning and as of noon today, have received no reply. I hope this is not an indication of a change in their quality standards. However, until I hear from them, I will not buy any Loctite products and caution others likewise.
Re: Loctite Rant
Any idea when it was made?
Dick Coers
That stuff could have been in a warehouse for months, on the store shelf for some time, then you let it sit for 1 year. Plastic is not the best container for long term storage, so likely it was well past it's shelf life.
Re: Loctite Rant
Temperature-related?
I've found that most epoxies in syringe dispensers are difficult to impossible to push out when cold. Have you tried warming it before using?
Re: Loctite Rant
Re: Loctite Rant
Chuck in Mtl.
I would package up the faulty product and send it to Loctite with a letter explaining the problem. More than likely the product has been sitting somewhere for months and went bad. Is there a use before date on the product package? Or a code of some sort?
Re: Loctite Rant
Re: Loctite Rant
Tom
I'm a real epoxy snob, but when I use the stuff in syringes at all, I get it from the dollar store, and it actually works really well. Can't see any reason to spend more. Save that money for the WEST.
Re: Loctite Rant
Re: Temperature-related?
jim Hoeller
The shop is in the basement and the temperature is at or above 65 degrees. I've used that type of dispenser before (it may have been a different variety of two part epoxy) and not experienced problems. The printing on the package had an application range of 39 degrees to 95 degrees fahrenheit so that does not appear to have been a factor.
Re: Loctite Rant
Re: Loctite Rant
jim Hoeller
If there is an expiration date, the printing is so small that I can't find it.
Re: Loctite Rant
take it back where you bought it ??
