Well, I un-clamped it.
Joe in a Cleveland suburb
It came out pretty well. Not perfect. But I think it will do.
I measured before I took the clamps off and after. There was zero spring back. I doubled checked this morning to see after sitting all night if it sprung a little, it didn't.
Recap of how I made this:
  • I made the form using crappy big box store plywood. Using a router on a tramel I routed out the half circles. I finished each piece on the band saw so I could end up with a 'U' shape.
  • I stacked all the 'U' pieces of plywood on a base. Each layer was glued and nailed down.
  • I bought 1/16" poplar and 1/16" cherry veneer. Ripped to rough width on the bandsaw. Each band was about 40" x 1/16" x 3-1/2"
  • Put packaging tape and wax paper all over everything so I didn't glue the apron to the base or masonite.
  • Glued up 12 pieces of poplar, then the last layer of cherry.
  • I used a foam roller and Titebond III
  • Put it on the form and then put 8 layers/bands of masonite (no glue obviously). Started clamping.
  • Let the set cure for a couple days and took the clamps off
  • What I learned/mistakes
  • I should have been much more precise/careful making the form - I probably should have used a router and a template or something to make each layer of the form the exact same after it was attached to the form - I know there are better ways than the way I did it. As a result, when I put the apron on the TS it is not totally square to the TS top. Also, it is not a U shape and actually decreases slightly in radius. This is going to make the joinery for the rear legs a little fussy I suspect
  • I was a little too conservative with the glue I think.
  • My cauls should have been bigger
  • Used too many layers of poplar. Not sure what I was thinking. I wanted this apron to be 5/8 or 3/4 thick. Why did I use so many layers? Always have hated math...
  • The biggest mistake was not taking better care when making the form. Next time I will know better...
  • That's all I can think of right now. So, it's not perfect, but it should work. And I'm looking forward to the next steps.
    Out of the form:
    #4 That block of wood on the left is there for no reason...
    Thanks.
    Re: Well, I un-clamped it.
    Jesse Cloud
    Looks good, especially for a first time! After you clean up the edges, if you see any small gaps between plies, you can fill them with epoxy.
    You are right about the form, it pays to spend a lot of time getting it just right.
    Thanks for sharing the project with us.
    Tony - Memphis
    Looks good to me. Thanks again for all of the info. I recently completed a round table. I used the brick method. That worked pretty well. Each new layer is routed relative to the previous layer and then becomes the template/pattern for the next layer. The first layer has to be right! I'd liek to try my hand at laminating. Lots of neat stuff one can do with the technique.
    Tony
    Looks great to me.
    I would set it on a flat surface and get it as level as possible and then scribe a line around it. Hand plane or sand to the line and then work from there. Be careful that the two back "wings" are parallel to each other especially if you are going to mortise the legs and put tenons on the rear. If you piece is twisted even a tiny amount and you reference the attachment off the surfaces the legs could be incredibly crooked. Clamp two sticks on them as long as the legs and see if they are (and Look) parallel.
    John Foster
    Very Nice;; I used a similar technique to make a bishop's crozier for a church play once. Worked well.
