Samantha's dresser 9- fixing a problem
Invariably handling the side panels winds up dinging them. In this case there must have been a hard piece of something on the bench, perhaps a glue drop. In any case I discovered a series if small dents caused when I slid the panel across the bench and the "whatever" rolled under it. Fortunately the fix is easy. A soggy wet rag and the soldering iron steamed the dents out in short order. As long as the wood is not torn steaming will push a dent back level again.
Next installment is cutting the veneer for drawer fronts. It did not go well.
