Wood Color around New Ceiling Lights
Cathleen
I just installed new light fixtures in a wood ceiling with smaller ceiling plates than the old lights. Now I have a ring of lighter color wood. I believe the wood is yellow pine that may have been finished with tung oil. The color difference is not a lot but it is very noticeable.
Would welcome any recommendations on what I might use to darken the wood just a bit. Thank you!
Re: Wood Color around New Ceiling Lights
Jason Roehl in Lafayette, IN
Well, what you have is that the wood that was covered has not darkened from exposure to light while the rest of the wood has. Anything you do to make it darker now will mean that as time passes you will end up with a dark ring as the wood underneath your efforts at darkening catches up to the rest.
Jason
Jason hits the nail on the head. Further, to even try to match the old color at one point in time, would require a whole palatte of earth colors and a lot of experimentation.
I think you woule be better off accentuating the transition from light fixture to old ceiling than trying to hide it. You could build wooden framing or trim, perhaps in a different color, to cover the transition.
Patience will fix the difference.....
The newly exposed wood is eventually going to darken equivalent to the other wood. If you darken this wood to currently match, when it darkens over time it will then be darker than the other wood.
Re: Patience will fix the difference.....
Steve Schoene
True, the wood will catch up in a while. But you might do something meant to be temporary to darken the ring for a while. For example a light coat of shoe polish might get closer in color but could be removed with mineral spirits fairly easily when it starts to look too dark.
Hmm
Good question. I think you could put some dye stain on those lighter parts to match the existing wood, without worrying about them getting darker as the UV and oxidation darkens the lighter wood. The thing about dyes is that they stay that color, and IME, they override underlying darkening, though this gets into some trickier explanations and probably many exceptions depending largely on the species of the wood.
I have often used sap stain, for example, to darken sapwood to the approximate color that I expect the adjacent heartwood to be in time. It's a matter of guesswork, but at least you can have a more natural looking appearance now.
Ellis Walentine, Host
Well, I think I may go against the grain here.
Keith Newton
I think I would use some Minwax stain on it. You can buy it in tiny cans.
You didn't mention how old the wood may be, so offering a color suggestion without seeing it would be anybody's guess. See if you can bring home a color chart, or buy two colors, lighter, and darker in the values that you think it should go.
If you take the new light down, the wood that it covers is where you test which stain will work best.
Alternate approach.
How about buying bigger rings? Or make some rings to add to the ones you have? Something like the medallions we sometimes put around light fixtures? Just a thought. No stain dripping off your elbow and easily reversible.
Re: Beat me!
I was going to post the same thing. I have used the larger rings on a couple of ceiling lights I replaced to cover plaster cracks and other issues in my 1880's home. In reality once everyone gets used to the new lighting fixtures, no one ever looks at the ceiling with a critical eye (if at all). The larger medallions come in various colors and / or can be painted to match the fixture. A half hour to drop the fixture, install the medallion and problem solved.
Cathleen
Thank you all so very much for the assistance!
My husband passed away 2 yrs. ago and, sometimes, figuring out the possibilities much less a course of action, has been quite an adventure. Your recommendations have been very much appreciated.
