Re: Back in December, Mr. Tindall...
Wooden shelves, boxes, and brackets to fit pegboard are easy to make, but do require a little fiddling to get them to work well. You could just screw and glue them to the pegboard, but that kinda defeats the purpose of the pegboard ;^). I usually make my own hooks to fit the brackets, from a pair of FHWSs. Don't use drywall screws, because they are too brittle and can't be bent to the requisite shapes. I drill two holes in the top rear edge of the bracket, a precise number of inches apart, at about a 45° angle downward (so I don't split the bracket), drive in the screws to prethread the holes, and mark the screw depth. I then remove the screws, clamp them (individually) in a machinist's vise, cut off their heads, bend them about 45° at the mark, bend them back 90° a quarter inch or so beyond the mark, and trim them to length about a half inch beyond the second mark. I usually used a hammer or a pair of vise-grips to do the bending. I then screw them back into the wooden bracket and do some fine adjusting so they slip smoothly into the peg board. To mount them, I tilt the bracket up 45° at the front, insert the hooks and push them in while rotating the bracket back down into position (just like you would with the flimsy wire brackets. I prefer to use screws with a limited length of thread and a long length of unthreaded shaft, so I don't have to file away the threads. You could also start with a 90° cup hook.
Sorry I don't have convenient access right now to a method to either photograph or make a drawing of my installation and post it here on WoodCentral, but maybe later this week, if my verbal description was only as clear as mud.
