THE WOODRAT IS BACK!
Router Plate
Router Plate
Router Plate
Jeff from Las Vegas
I just recently bought a Ryobi routerI need to know where I can purchase a plate that goes on the bottom for me to do dove tales and finger joints on a jig its 3 inches in diameter and the plate supports the router bushings on the dovetail jig any systems for help thanks Jeff
Re: Router Plate
Re: Router Plate
I don't own a Ryobi so I can't answer directly, but most routers have a way of attaching the bushings. We would need to know the model of the router. I hate to suggest breaking the Man Code here, but look in the booklet that came with the router or if you did not get one, Google it and you should be able to down load a PDF of it. It may be an accessory base plate.
Re: Router Plate
Re: Router Plate
Keith Newton
Jeff, the term you need to enter for your search is this.
ryobi router template guide bushing kit
Along with the model #. If you can't find the kit, or the one size that you need, look for an adapter that will allow you to use another brand of bushing like PC.
Re: Router Plate
Re: Router Plate
The Porter-Cable bushing "standard" is the most common and I think the easiest to use. I wouldn't buy a router that didn't come with a base plate (or adapter) that these bushings would fit. However, if yours doesn't, all is not lost. There are several "universal" plates available that have attachment holes for many common routers, and even plates with the PC bushing mount, a centering pin, and no holes, so you can drill your own to match your router.
Here is an example. It says it fits ryobi, but doesn't provide any model numbers. http://www.woodcraft.com/product/2004856/7680/router-base-plate-with-centering-pin.aspx
My recommendation is to bring your router into a retail woodworking store with you and try out the plates they have on hand. If you are also buying the bushings, be sure to try them out with the plate at the same time. I've encountered (rarely) third party PC style bushings that did not fit the third party PC style plate that was right next to them on the shelf. I've also encountered plates that don't fit (or that don't have the right size screws) the routers they are advertised to fit. That's why I prefer to buy genuine PC routers and genuine PC bushings.
Re: Router Plate
Re: N. B.
Note that the illustration of the Woodcraft router plate example is an oxymoron. The photo shows a Porter-Cable router and a Porter-Cable bushing, so for this particular case, the after-market plate is superfluous, because the standard plate that comes with that router fits that bushing perfectly. The clear plate, however, does show the concept very clearly, and also gives you a better view of your work and your dovetail template. Dovetail template fingers are very expensive to replace if you hit one with a router bit. Some fingers are made of steel, which means you also have to replace your router bit.
Re: Router Plate
Re Pat Warner plates
Jerry Nicholson
I bought a couple of Pat Warner's router plates for my Dewalt 621 several years ago and found the quality, and the service from Pat Warner, to be great.
Jerry
