Went to plug in a simple inflator on my inherited air compressor and found that the plug would not fit into the female receptor on the hose. They looked the same other than length. I did a little checking and found that there are various sizes of fittings, with, seemingly, no single standard.
What size would be the most logical to go with? I have hopes of buying a brad nailer soon. and I would prefer that the connections fit without hassling with switching them out.
I don't know about that, but when I go to modern stores like Home Depot, Harbor Freight, etc... All the fitting are the same, and it has been like that for over 25 years. I am taking about the standard size, there are larger hoses and stuff, but all the nailers, drills, spray guns, staplers, wrenches, etc... use the same size stuff.
I was an auto mechanic years ago and what I used then was totally different from what is used commonly in woodworking today. This chart might help a little. I believe what we use commonly is type M. Just see what type they sell with woodworking air tools and compressors that are built for woodworking applications.---Jack
I work at a hardware store that carries the Topring brand. I don't know why, but there are more fitting variations than you can shake a stick at. I guess you have to decide always check.
I just looked at Home Depot. Theirs are labeled IM I think its I/M Or I-M. These are for wood working stuff. They have others label with a T for Automotive. The fittings are clearly different. If you looked at all you would not make the mistake.
It seems to me that there used to be more subtle variation floating around but for the last twenty years or so they have standardized on the M version.
There are four principal types sold in the US- Idustrial Milton, TruFlate, Aro, and Lincoln. In Texas, at least, Industrial Milton (often labeled "IM") is the most common. It really doesn't matter which you use, as long as all of your fittings are the same type. I work for Forney Industries, and if you find one of our displays selling air fittings, it should have a little sample bar of all four types so that you can figure out yours.
Until I took this job, I thought that there was just one kind- I figured that the whole thing had been standardized long ago- shows what I know!
Whenever I've purchased air hoses and air tools, they have always come without fittings, presumably for just this reason. Whatever you decide on, switch over all your present fittings and buy a couple extra male and female ends. I don't think there is a functional difference, just dimensions.
The big box stores and other hardware/tool suppliers now carry a female coupler that takes both M&T fittings. I believe the M’s have red tape on them and the T’s have blue or visa versa but if you look more you will find couplers that have both blue and red tape that work with both styles of male fittings. I’ve pretty much changed all my couplers in my shop so no more hassles.
