I finally did it....
Joe in a Cleveland suburb
I finally glued up the veneers today for my little half-round table.
Applying the glue with a foam roller was un-eventful. My wife gave a helping hand also. Hope I wasn't too conservative with the glue.
I'll let it sit in the clamps for a couple days. I'll get started on the legs in the mean time.
I'm excited to unclamp it though to see if it comes out good or if when I undo the clamps it goes twang like Clark W. Griswold's tree did when he cut the string...
Don't look too close, you might see an error or two.
Oh well, fingers crossed.
Re: I finally did it....
Looks good to me. I have never had one come out that "clean". Did you wipe off the Squeeze out? I think you got it. It will be easy to rip down. I an anxious to see it out o the clamps. 24 hours should be enough, but more won't hurt.
Jesse Cloud
Looks great! I would be surprised to see much of a "twang".
Bet it weighs a ton with all those clamps!
Tell us about the legs! What kind of joinery are you planning?
waroland
You needed a few more clamps! Ha Ha. The glue-up looks great.
Hadron Collider?
At first glance I thought you had built a model of the Hadron Collider, using clamps as the superconductive magnets and cherry as the track.
Testing. When you size the band you can test the lamination by poking at the cut off strips and seeing if they come apart..... or not.
"Tell us about the legs! What kind of joinery are you planning?"
What kind of joinery am I planning? You mean I'm supposed to plan this stuff out? :)
Actually, the front leg will be attached with a bridle joint. The back two legs will be attached with tenons. The back apron will be attached to the two legs with a dovetail joint.
The legs will be turned - a simple taper. It's all Cherry except the top. I plan on using a nice piece of curly maple for the top.
That's the plan (in my head) anyway. We'll see.
I'm going to un-clamp it tonight to see how it looks.
Thanks.
whoa
That went right over my head. Googled it. Confused. Too brainy for me! :b
OK Joe, Pull the clamps....
and let us see what you got. Pull them in reverse order. Middle out. Look it over and show us a picture. I'm betting its good.
I will!  Maybe...
I will show you a picture, unless it's too embarrassing... :)
Those are good too, for the rest of us....
We can diagnose your mistake and not make that one next time, maybe. Go for it.
Are you saying that those 3 thick plys
Keith Newton
are cherry too? I wish I had looked at this sooner. I would have suggested using more, thinner plys. So how much spring-back did you get?
If you are planning to cut away the straight away portions after the glue dries, there may be some more spring-back, and a little bit of straightening of the curve then, so after you take the clamps off, take some measures there before you cut, and after you cut, so you can share that with others. Otherwise, nobody will know, and yours may become the standard for others to follow.
I usually hit the first side with a power-plane, then run it on the TS.
Re: whoa
Here is a picture of the ATLAS (A Toroidal LHC Apparatus) experiment:
http://www.atlas.ch/photos/atlas_photos/selected-photos/full-detector/0610006_01-A4-at-144-dpi.jpg
and a picture of the CMS (Compact Muon Solenoid) experiment:
http://3.bp.blogspot.com/-ATMdSckGjYI/UYfWzzUtvzI/AAAAAAAAAFs/7ef511XATpo/s1600/lhc-cms.jpg
These are parts of the CERN (European Organization for Nuclear Research) LHC (Large Hadron Collider).
You never have enough clamps.
No.
I think you are referring to the outer bands of masonite. There are 8 masonite bands, then one band of Cherry and the rest (I think it was) 12 bands of poplar.
So the actual glued up apron consists of 12 bands of poplar and 1 outer face bans of cherry.
The actual cherry and polar bands/veneers do not show well in the image.
Hope I'm making sense.
