Still fooling with new toy, Compressor
Keith Newton
In an earlier post, I mention getting a new carry-around compressor, and wishing to make it quieter. I still don't have the new silencer/filters, but have modified the one which came on it.
If you press your lips together, and suck in hard against them, then quickly open them trying to make a popping sound, this is essentially what is part of the source of noise for lots of small compressors.
This new one has a single cylinder driven by a direct drive 3500 rpm motor, so it produces a pulsing implosion 3500 times a minute, or 58 per second. You can unscrew the filter, and place a finger over the hole, blocking all inflow to see how much noise goes away by eliminating that.
This one has an inclosed oil crank-case, so I'm not getting any noise from under the cylinder, which I think may be where most of the noise comes from most oilless compressors.
Anyway, I rolled up a old wool sock and stretched it over the stock filter, and was pretty happy with the noise reduction. I drained the tank, and ran a full cycle from empty to full pressure with and without the sock. It took about 15 seconds longer with the sock on the stock filter. It takes one minute without the sock.
I had already been thinking about drilling a few more holes in the cap of one of the new ones, still on the way, but then though, why wait? so drilled 3 additional holes in this stock filter.
This should cut the velocity of the air entering the top of the filter by 75%, and with the sock back on, the noise is even lower, and the cycle time is back to the one minute shutoff from empty time. I don't expect the new metal filter which is in rout to me will improve this any, but it is good to know, and I thought worth sharing.
Now, if some of you have one of those really loud oilless ones, besides doing this, I would be looking to see if there is an exhaust port for the underside of the cylinder that I'd be trying to muffle that end too.
