dewalt 735 planer
gary clarke
What is the minimum (thin 1/8 or 3/16) can this planer get a board? My Delta is wearing out and will work down to 3/16. Also are the heilex blades worth the extra cost?
dewalt 735 planer
gary clarke
Re: dewalt 735 planer
It depends on the board. Each board is unique, but in general, the thinner the board the higher it's resonant frequency. Also, a board that is held down forward and aft by a roller is not going to bounce up and down as much as a board that is being pummeled by a sequence of blades and only constrained by one roller. (Usually, the catastrophy happens at the beginning of the cut, while only the infeed roller is engaged.) So, a helical head is going to drum the board up and down at a much higher frequency than three straight blades, and a much thinner board will accept that drumming without bouncing up and down in time with the planer, and therefore will be much less likely to shatter when it gets in resonance with the rotation of the cutter head. A more traditional way to successfully feed very thin stock through a planer is to use a (flat) carrier with a strip of double sided tape at the front and back ends of the stock, to keep it from bouncing. This strategy works very well with the DW735, since it's design minimizes (almost eliminates) snipe, and thus minimizes the problem of cutting through thin stock all the way down to the tape. Instead of equipping the carriage with double sided tape, another strategy is to build the carrier in the form of a vacuum table. This adds complications to the process, as you have to turn the planer off before the line supplying the vacuum gets eaten by the planer, and then either disconnect it, or pull the carrier and the stock back through the planer for the next pass.
(Ref. earlier thread on thickness sanders for alternatives.)
In general, a planer with helical heads should successfully plane thinner stock than traditional blades. (There are also other significant advantages to helical heads.) All else being equal, a planer whose infeed and outfeed rollers are closer to the cutter head should be less prone to shattering a thin board. I have not done those measurements, so you'll have to do the measurements yourself. It also makes sense that dull blades would be more likely to shatter a thin board than sharp knives.
David Yoho
I have an older 13" - two-speed Delta. I am able to get to 1/8-inch or less with it by adding a piece of 1/2" MDF that is the length of the infeed to outfeed tables and as wide. There is a cleat on the underside of the infeed end to prevent it from being pulled through (not that this has happened so far).
I have a helical cutterhead on my 8" Delta jointer and love it. However, I'm not convinced using one on a lunch box planer is worth the extra cost. The lunch box planers run at a higher speed, which seems to produce a nice finish. Whenever I'm running something like curly maple through my planer I will either feed it in cocked or wet the top surface with a sponge or both to prevent tearout. It works. Also, the lower speed on mine helps a lot in that effort.
Tony - Memphis
I've had the 735 for several years. I've not tried anything thinner that 1/4" based on previous experience. So, I'm not sure what the limits are. As noted, I tape thin stock to a carrier board.
I added the Byrd cutter head last year (Santa brought it). I like it so far. I've had some issues with breaking cutters though. I may be using too much torque? I am using a torque wrench, but it could be out of whack a little. I have not gotten the glass smooth surfaces I was used too, but...I have thrown some awfully nasty figure at it and gotten great results. Doesn't seem to matter which way you run the wood through either. It also leaves very slight ripples on the surface that must be sanded, scraped, etc. (which most folks do anyway - doesn't seem to take any extra effort, but you see them and it bothers you). I do like it better than the knives. I was constantly working around nicks. Overal, I like it and am glad Santa brought it. Is it worth the money? I can't answer that. I read a post a while back that did some math on the cost of adding the head vs. buying a larger planer with a head included and it was somewhat convincing of saving a while and buying new (I already had my planer and head though).
I've been very happy with the 735 in general. I still get some snipe now and then, but it has been a great tool. Nice and heavy and has never skipped a beat. The only issue I have had is the dust colection cover that covers the knives broke. I epoxied it back together and it is still working. I may have to replace it someday. The dust collection on this tool is great.
Tony
Re: dewalt 735 planer thanks for the help
May not be planer limited
The mechanical properties of the wood begin to become important somewhere in this range and how they interact with the details of how the planer is set up. On my 18" ancient Powermatic it would in principal plane something 1/16". However, I find that some boards 1/8" can develop vibrations that get out of control and splinters come out the dust shoot. A backing board solves this problem down to 1/8".
One little trick that I do on thin.
Keith Newton
Once I put my melamine sub-base on it, and get down to where I worry about the front edge lifting off the bed at which point it gets eaten. I use my power-plane to put a long tapper on the top, so the front end is under the out feed roller, before the blades touch the wood.
Combine this with sharp knives, and wetting, if you have some wild grain, will help any planer go thinner.
Could be dicey
I used to routinely plane laminates and sawn veneers to 1/8" or less, but only on my old Inca jointer/planer, which had a high-speed cutterhead, carbide knives, and an effective pressure-bar mechanism. You also have to be very sure that you're planing the right direction on the grain. I've had equally good results with various small lunchbox planers with universal motors. The high cutterhead speed is the key, at least based on my observations. We never planed anything thinner than about 1/2" on the big 24" Buss planer because that thing wasn't designed for delicate work like this. I think the DeWalt 735, with the full-size knives and the lower cutterhead speed, might be problematic, too. Taping the piece to a sled board might be the best approach.
Re: Could be dicey
I have the older version, the 733 I think. I tried to feed some very figure walnut root through it at about 3/8" and it exploded, leaving nothing but slivers. worked the rest of it with my Performax.
I would say that if you are going to feed pieces through taped to a sled, and get very thin, and you require extreme accuracy, you might find that the thickness of the tape becomes and issue and shows up like snipe. I have sanded things so thin on the Performax that it sanded through where the tape was.
