Crystal Varnish Repair on floor
Bill from Montreal
I have a relatively new house with stained oak flooring with Crystal (urethane) varnish on top.
In many places, the varnish has glued the boards together in bunches, and about every 4-6th gap between the boards open the gap in the winter when the collective bunches shrink. (Called Block effect)
My problem is in a couple of places, the varnish has lifted off or cracked away from the stained flooring, leaving areas withbare stained oak. Luckily so far, the stained wood is still intact
Although the Crystal varnish surface has held up well, our two labradors refuse to wear the slippers provided, and some marking of the surface is present
Crystal (urethane) varnish is no longer available in Canada due to VOC and pollution restrictions.
resanding the entire floor should not be necessary (and undesirable - the stain is dark and would require a deep sanding)
- I think a recat should fix it if I can find something to bond to the Crystal
I want to
a) repair the chipped spots (three sections, about 24-30" long total)
b) consider recoating the main floor to reduce or hide the dog scratches
Any Suggestions? What sticks to urethane, for spot repair, and for general recoat after light sanding....
